20 bucks via paypal to anyone who can get this working...
so i installed mp not via the installer i didn't see it so i just manually loaded the driver and all worked fine. but realizing i didn't have the 3dr radio drivers i removed and reinstalled mp via the install tool and now i get com port does not exist when trying to connect.the driver is loaded i can see the driver and the board via device manger and i can see it in the drop down in mp to select com3 but it will not connect.Now i did make the mistake of having the 3dr radio plugged in when i connected to usb. could i  hurt the board ?  figuring i some how messed up windows and drivers, i loaded a fresh mp via a fresh download of the installer to a second computer...it loaded drivers etc... and i have the same problem  com port does not exist ? its just on com 5 now on the new pc, i give up did i hurt it buy plugging it into usb with the 3dr plugged in ? Now to top it off windows will not see my uno board. some how the driver via mission planner has bricked my comports on both my pcs i tried to plugging in my wii aiop pro and it its dead too... windows still sees it pluged in ever when the apm2.5 is not and i can not un install it it just locks up ever on a reboot with no board plugged in its there? first machine is a xp laptop and the second is a vista desktop. at this point the both do not work and the trackpad on the laptop is dead i had to plug a mouse in ?i thing some how the apm some how bricked with the reload of mission planner and now has hijacked drivers that are messing with comp /usb's on both computers and i can not uninstall it ?
reinstall the device driver in device manager, should fix it
have you tried looking at your restore points in windows. You might be able to get back to a state before things started to go bad for you.
Are other things working when plugged into the USB port?
With my xbee I was in a situatuon where I thought that I had burned it off, but thaking it through the re programming I was able to get it to work again.
Mario
I had this very problem and I did figure it out!!! I've got multiple APM 2.5's they connect on a different comport, one connected ok the other will be seen via the comm port but will not connect... It drove me batty for about a week but I finally licked it... This is what you need to do plug-in the one that will not connect to mission planner go to device manager and go to the ports and you should see it listed.. Right-click it and select update driver I know I'm sure you've done this before and it didn't work but there's one step that needs to be done When it asks for automatically searching for the lower option that says that you will select it pick that one. It will auto populate drivers that Windows believes will work there will be two listed one is digitally signed With the check mark next to it and one is not. Select the driver that is not digitally signed and apply/okay it will give you an error stating it is not digitally signed. ignore it And Bam the problem is fixed as the do with windows grabbing the driver from the Arduino program versus the mission planner program they both have the same name however they are definitely different, I guarantee That is your problem do not let Windows auto select the driver for you or install it automatically manually select the driver it will list two and do not pick the one that is digitally signed If you can't sort this out drop me a p.m. I'll walk you through it
dear chris wilson,
could you pass me the correct driver for the usb 3dr telemetry kit, I went to device manager and did what you suggest but the list of divers is big (around 8 drivers) and I´m not sure which one to choose.
thanks!
Ernest
run safe mode and fix it trough there everything should be fine you could also try to hook it to a different usb port rear for example
next time first driver then device unless you cancel the windows auto driver installation and use your own drivers when plugged in for the first time
best regards
Hi guys. Just got brand new APM2.5. Old one (bought  10/12) runs fine but need to make second drone. Unfortunately MP refuses to connect to the new one ! Same PC connects to old one just fine. Tearing my hair out ! Strangely when I plug the older one into the USB port it shows up as Mega2560 on COM4. But when I plug in the new APM2.5 on the same physical USB port it shows up as Mega2560 but on COM8. Clues ?
Thanks, - Vijay
Just change COM port to COM8 in MP. It is dropdown near Connect button.
If it is not shows up then delete Mega in Device Manager, reboot.
Wait untill it finish with driver installation process, then run MP.
Hope this helps,
Alex
I have the same problem, have been pulling my hair over it for some time now. At this point, I have tried eveything under the sun, I can no longer connect my APM via USB. I can only see it when it is powered alone and broadcasting via the 3DR radios.
And since you can`t do a firmware upgrade over the radio, well, I am stuck. I am not happy with this because I wasted a huge amount of time and now the board sits in a box. Going back to the DJI Naza for a while until the bugs get ironed out, it`s just too frustrating. And my minimOSD won`t connect either, probably a corrupt bootloader. Royal pain, not time for this right now. I hope you figure it out and if you do, please post your findings! Good luck.
I changed the COM port to 8. Uninstalled, rebooted. POwered off .... MP will not connect to the new APM2.5. !!! I cannot even connect using the 3DR radios. HOWEVER, the older APM2.5 works just fine. Connects with USB or 3DR radios.
Some big issue but 3DRobotics customer support is still pretty non-existent so the only hope is someone smarter than me will figure this out. Anybody else got new APM2.5's in the last few days ? Do they connect ?
- Vijay
I battled with this same problem it has to do with windows grabbing a generic Arduino digitally signed driver for the 2560, even though it has the same name it will not work with the APM. Simply go to device manager and right click update the driver but do not let it auto select or automatically find the driver select the lower option Which is you manually telling at which driver to use the next screen should list drivers that are compatible for the APM the top one is a digitally signed want with a checkmark that Windows Picked for you automatically this one does not work even though it recognizes it and doesn't indicate a problem below that should be another driver with the same name that is not digitally signed and does not have a checkmark next to it that is the driver you want selected and apply it it will give you an error stating it is not digitally signed ignore it once you've done that Just reboot and going to mission Paner pick the appropriate comm port from the drop down and bought right and you should be in like Flynn
Chris:
Thanks for the response. I have two laptops running Windows 7. I tried your suggestion on both of them but  no luck. Just the same - timeout on connection. The installed driver is dated 11/15/2007 version 5.1.2600.0
My feeling is that this is the FTSI chip driver but the mega does not use the FTSI anymore so it does not work. I cannot find any other driver. Almost feel like throwing the APM in the trash.
- Vijay
