4215(3507) 650KV Multicopter Brushless Motor and prop help
Ok i have been trying to get a few answer to finish my build and i am coming up completely empty.
I have a
and a couple differ size props to test with. I have 30 amp esc and running 2 4s 5000mah batters to make 10000mah.
I cannot figure out what props to run to get a decent run time and a good lift value but still be under the amp and wattage rating. Here is what is said about the motor from vendor.
Volts
Amps
Watts
Thrust
APC 12x3.8SF
11.96
13.85
165.6
1'25"
APC 12x3.8SF
15.6
22.1
341.6
3'9"
APC 10x4.7SF
12.01
9.55
114.1
1'10"
APC 10x4.7SF
15.6
14.75
230.1
2'9"
Prop
Volts(V)
Amps(A)
Watts(W)
Thrust(g)
Efficiency (g/W)
12×6E
7.4
5.2
38.48
382
9.93
8.5
6.5
55.25
512
9.27
10
8.6
86
716
8.33
11.1
10
111
844
7.6
12.8
12.5
160
1066
6.66
13.5
13.6
183.6
1165
6.35
14.8
15.7
232.36
1386
5.96
13×8E
7.4
9.2
68.08
607
8.92
8.5
11.2
95.2
747
7.85
10
14
140
905
6.46
11.1
16.5
183.15
1053
5.75
14×7E
7.4
7
51.8
552
10.66
8.5
8.6
73.1
701
9.59
10
11.1
111
910
8.2
11.1
13
144.3
1083
7.51
  • Weight is 2890 grams with both batteries and 2 gopro cameras.
