Wasn't sure where to post this.. but are these at all useful? I guess they would have to be tested and measured against standard grommets. Not sure how "new" this is today...
Tags:
Permalink Reply by eric on May 28, 2012 at 8:38am Guess not all that new, found another similar model: http://j.mp/KKcAw1
Permalink Reply by Crispin on May 28, 2012 at 8:43am I used the silicone PC fan mounts. They work perfectly. The thin side fits snugly through the APM holes and the fat side fits snugly through 3.5mm holes drilled into the quad's top board.
They a dirty cheap as well (if you don't have them in your parts bin anyway...)
For the motor mounts (3DR quad) I used silicone washers under the motor (between motor and arm) and used the same same silicone washers to insulate the quad's carrier board from the main frame.
Again, for about 50p I got 20 of them :D
Yeah, not new. I've got some just like that I used to mount an APM2, but I'm not that impressed. Probably better than nothing, but not great by any means.
Permalink Reply by Crispin on May 28, 2012 at 8:49am probably granny and eggs here but, How tight did you make them? If they're compressed then anything will transmit the vibration.
Permalink Reply by Crispin on May 28, 2012 at 1:07pm Eric,
I'm no expert on this but my take is that, it would be better than nothing but if you tighten it up, even slightly, then the silicone would be compressed and transmit most of the vibration. If your nut was a nylock type of nut, this could be mitigated.
Seeing as your top plate is nothing other than holding the electronics, why not look at the fan mounts. For example: http://images.highspeedbackbone.net/skuimages/large/S23-1084_main_i....
I've mounted them standing up. So the fat, blind end, is pulled through the quad's frame and then through the APM. The APM then is basically resting on it. Because of the various lips, it cannot move.
It would be interesting to set up a vibration sketch with using something like a piezo as a sensor and measure different methods. I'm going to guess that various methods will dampen various frequencies and pass others through.
Permalink Reply by eric on May 28, 2012 at 1:30pm Oooooh FAN MOUNTS!!! I see :-P I thought you ment something like this: http://j.mp/LCsaGL. You may be right. I think its worth a test..
BTW, If you have an iDevice, you can strap it to your construction and test these methods using the "Accelerometer Data" app. Many people use the app to test vibrations in a variety of constructions. Theres even an app for macbook, and maybe for android I'm not sure...
Permalink Reply by Crispin on May 28, 2012 at 1:36pm Thanks for the tip. I'm an iDont though :)
I'll see if I can play with the code or write another sketch to measure the data.
My current setup includes props which have not been balanced (but my home made balancer says they're ok :p) and two motors with slightly bent shafts. I can throw the quad around and it's quite happy. it'll also sit and hover dead still.
When about 1/2 throttle there is washing machine type vibration which can be heard a long way off. It does not seem to affect it and I chalk that up to the silicone washers under the motors and fan mounts for the APM and carrier board -> frame mount.
One day I'll change the motors ;)
Permalink Reply by eric on May 28, 2012 at 1:43pm LOL, I'm an iDid ... iT broke but iWont because i'D rather built a quad than be an iDid it again...
Sound fan mounts have proven themselves. I may do this for the carbon plates, but I' sold on the boards. Thanks for your input!
Permalink Reply by Crispin on May 28, 2012 at 1:47pm just a thought, I got some CF plates from a friend (off-cuts from a Boeing's wing! How cool is that) which I will be using for a quad. he warned my that the edges are stupidly sharp. Unless the drilled holes are very smooth (polished?) could they not rather quickly cut the silicone?
Might be worth buffing the inside of the holes? Like I said, first time novice with CF so don't know much (other than it's impossible to bend!)
Permalink Reply by eric on May 28, 2012 at 3:32pm I imagine thats gotta be some hi-grade material! Any cutting or drilling should be done with special diamond treated CF tools. You don't want to damage or pull the fibers. They can run like a stocking and ruin the goods. Then you should seal the cuts with epoxy.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.677 members
1284 members
24 members
4 members
8 members
Powered by
