Tags:
Permalink Reply by Rick Eis on August 29, 2012 at 7:24pm I'm having the same problem ~ 1 click and it goes up and one click down and it will go down ~
Permalink Reply by DanRZ on August 30, 2012 at 12:40am Hello, multiple causes can be possible, i think :
1 - Wrong calibration of throttle course on the ESCs. Solution : Recalibrate all ESCs.
2 - Too "strong" prop. Solution : Change prop and reduce diameter and/or pitch.
3 - Too "high" motor. Solution : Use a motor with less Kv or use a "lower" battery voltage.
Another solution is to use a throttle curve on the transmitter to "smooth" throttle
like using expo on other commands ...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
75 members
24 members
184 members
685 members
Powered by
