Hello, my name is Alejandrina, I'm Ingenieer in agronomy production from Argentine I' m an Ardupilot happy owner for my new Skywalker, I'm newbie with RC and autopilot, my idea is to obtain aerial photos of the crops to help me to decide fertilization in presicion agriculture; my english is very bad but I'm going to try to participate in this very useful forum.
Here's my New plane on It's first day
Here you can see the Ardu and the minim in the top and the Dragon downside
Finally the minim moves in front of the plane fro interferences with gps
I have to decide how to attach the compact camera
For the moment I attached the camera like this
Tags:
Permalink Reply by Jerry Cresp on July 16, 2012 at 11:27pm See attached for what I hve done; one camer is RGB and one is NIR.
Permalink Reply by Cala on July 17, 2012 at 3:58pm Tanks Jerry, good idea, What NIR camera do you have?
Permalink Reply by Jerry Cresp on July 17, 2012 at 8:47pm I bought 2 Lumix DMC-TS3 s.
http://www.techrific.com.au/panasonic-lumix-dmcts3-dmcft3-digital-c...
I paid an additional $600 to have them both triggered electronically (at the same time) and one modified for NIR and 'matched' to the other camera.
Attached you can see a simple test sample result (low resolution) generated by the free MultiSpec software.
Permalink Reply by Dean Walker on July 18, 2012 at 11:01am Where did you
Permalink Reply by Eric Schall on July 18, 2012 at 7:06pm What kind of modifications did you do for the NIR camera? Was it simply a removal of the IR cut filter, or was the Bayer filter removed too? If the Bayer filter is still attached, which pixels do you use for NIR?
Permalink Reply by Jerry Cresp on August 5, 2012 at 10:10pm No, unfortunately.
This was one of the modifications that I paid for. The camera mechanic took out the battery and put in some electronics that enabeled me to trigger the camera externally by touching two wires together. This is done with a standard servo and controlled by the trigger command in the autopilot. A bit primative but effective.
Jerry
P.S. I wish I spoke and wrote spanish.
Permalink Reply by Eric Schall on July 17, 2012 at 8:04pm Ive been thinking about the same issue as well. Id like to capture images in VNIR in order to calculate NDVI and other metrics. Most of the available cameras are visible spectrum only and have a Bayer filter (2 green: 1 red: 1 blue) and an IR cutfilter to block infrared. The websites Ive seen about IR photography are more artistically oriented and the photographer removes the IR cut filter but not the Bayer filter. In order to get useful data from this camera, youd have to chose one of the three values or average them. The best approach to capturing VNIR images would probably be to use a splitting prism and 4 CCDs, but that is probably too expensive. The page [ dpfwiw.com/ir.htm ] has some useful information about various filters for IR photography.
Permalink Reply by Cala on July 18, 2012 at 6:19am Thanks Jerry, beautifull Photos
I was investigating the ir cameras too, saw the Tetracam but is expensive and low resolution, but I find something interesting that if you remove the IR filter and block the blue light, you can use the blue band as IR band and is possible to obtain NDVI with only one cheap camera, i have a doubt whit the exposure speed you can obtain with this metod.
Permalink Reply by Francisco on October 8, 2012 at 12:42pm Cala, yo he estado analizando este tema también y tengo una pregunta. Una vez eliminado el filtro, los tres canales RGB captan el infrarrojo, pero el verde y rojo además el espectro visible. Dejando el canal del azul al margen al usar el filtro, ¿cómo un pixel sabe si la energía que capta proviene de la banda infrarroja o del visible? ¿hay un algoritmo que compara los tres valores de pixeles cercanos y calcula en que lugar del espectro está la radiación recibida?, como sabrás un pixel solo capta o verde o azul o rojo, no simultáneos puesto que la cámara realiza una interrepolación posterior. Filtro Bayer,
Me interesa mucho este paso para tener una cámara IR-R-G a partir de una comercial
Gracias
Permalink Reply by Jorge Alarcon on July 18, 2012 at 8:48am Your project so far looks fine. Keep us updated on this project.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.5 members
1356 members
54 members
203 members
88 members
Powered by
