Is there a schematic or pinout available for the airspeed sensor breakout board?
https://store.diydrones.com/Breakout_Board_MPXV7002DP_p/br-0004-03.htm
The pads around the holes on my board are now damaged, and I'm trying to salvage what I can since the items are currently out of stock. Any help would be appreciated.
Andy
Permalink Reply by Jake Stew on July 16, 2012 at 12:45pm I think this is it...
http://store.diydrones.com/ProductDetails.asp?ProductCode=KT-0001-01
This should be essentially the same. You can also check out how the sensor board is laid out for more help. Better double check everything though. Hopefully someone can confirm.
Permalink Reply by Andy Grose on July 16, 2012 at 3:16pm Jake, that was just what I was looking for. The picture you posted allowed me to trace the components. I was able to uncover the necessary traces to solder to and directly soldered a servo lead to the board. Airspeed sensor is working again! Yeehaw!
Thanks for posting that!
Andy
203 members
720 members
1355 members
207 members
Powered by
