It seems that I'm constantly having problems with my airspeed sensor and the values it reports when I'm at the field. However when I'm sitting in an enclosed room I run tests with a fan and my anemometer and the sensor is almost dead accurate. I have read several posts here mentioned that you need to be sure that the pitot tubes aren't pointed into the wind when you turn on the APM, which I try to do each time, but in the field I get extremely inconsistent results.
Just yesterday in about 1m/s winds the airpseed sensor was reading 17m/s and the ground speed 8m/s while flying into the wind. Curiously though the indicated wind velocity in the mission planner was only 2m/s at altitude, so it seemed to figure that out on its own somehow. The only time I've managed to get the airspeed somewhat accurate is when there was on an extremely rare day where there was absolutely zero wind.
Of course having an airspeed sensor that is completely inaccurate wreaks havoc with the PIDs, one flight could be perfect and the next could result in a stall/crash if the APM thinks the plane is flying at 17m/s and throttles back too far. The only difference being the direction of the wind relative to the plane when it was first plugged in, combined with gusts and wind flow around obstacles it can be difficult to get this right.
So my question is: Similar to the manual level mode for the accelerometers/gyros, is it practical/possible to have a similar manual calibration mode for the airspeed sensor? I realize temperature and air density all play factors, but based on my own experience it seems like it would be more accurate to calibrate it in a controlled environment then taking chances with calibrating it on the field. The manual level mode has been wonderful for me in this regard.
Even better would be some sort of algorithm to automatically adjust the calibration based on in-flight data, similar to the auto-calibration of the compass, but that is probably much more difficult.
Tags:
Permalink Reply by Jake Stew on June 25, 2012 at 10:20pm I'm curious to hear about this sort of thing also. Maybe you could find or make a cap for the pitot tube for field calibration?
Permalink Reply by Mike on June 26, 2012 at 10:12am Yeah, I was thinking about that, but it can't create any type of seal otherwise that can cause problems too...
Permalink Reply by Jake Stew on June 26, 2012 at 12:56pm I don't have mine installed yet. I was planning to make my own pitot tube and just dead bug wire the sensor.
What you want though is equal pressure for both airpaths. So all you should have to do is put a bag over the end to block any wind. Otherwise you could find or make a cap that doesn't seal the end or to the sides, just around the tube at the mouth of the cap.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1356 members
54 members
203 members
88 members
24 members
Powered by
