Hi!,
  I almost have my 540mm Qaud finished.  I've got the ESC all calibrated,  I've got APM 2.5 loaded.
I'm configured, all the motors are turning right but there's something oddd.  I calibrated my radio
but throttle is messed up.  All the way up on the throttle the motors stop, drop down the throttle just a hair and I am at full throttle!   then pull the throttle towards me and eventually I get to low throttle but not stop.
I have a Spektrum DX 5e, how do I fix this ?
Is there a way to combine channels 5 and 6 to get more flight modes ?  With the Spectrum 5e you can select 2.  flight mode 1 and flight mode 6.
Has anyone modified a spectrum dx 5e with a rotary switch in place of the toggle ?
  • Ping.. I may of answered my own question.  Can someone verify ?  When calibrating the radio I need ESC BEC to  powering up the reciever, even though I was powering up my APM 2.0 via USB.   So, all I really need to do is remove the props and calibrate.  Also I should use the cli interface an calibrate the motors.
    Can someone verify?   Thanks.
