Hello
Im having micro (in duration) glitches/ flickering (micro accelerations) when fliying my new apm2 X quad, in order to identify if they are radio problems (they are not!!) , motors, vibration, PID adjustements , or the apm2 itself, I want to ask :
is there any relevant info in the logs that i can analize? how? i ve changed 2.4 receiver and placed gaui board, and still the same random glitches. thanks for any clue.
i can generate logs (after solve problem not inserted memory) if needed
NOTES
*My HK frame has integrated PCB http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
* XQUAD - 8045 props and 2212-15 930kv motors HELP ME PIDS Are defaults!
* Futaba 7cap 6 modes-
* ADC 2.7.1
UPDATE: it is not radio problem , I ve just replaced APM2 with GAUI330X electronics and works 100% free of any glitch. Frame is also ok (a little heavy but ok). Something in APM2 is causing those microglitches HELP!!
Tags:
Permalink Reply by Flavio BSB on August 6, 2012 at 9:14pm I am having the same problem. How do you solve it?
Thanks.
It is seem that the APM2 is muuuuuuuuch more sensitive to vibrations than any other fly electronics that i have tested, so i tried to minimize and insulate the vibrations everyehre i could. just that. rest seems to go fine, loiter is great. goog luck
Permalink Reply by Darren Stan Oakley on August 8, 2012 at 3:52pm Finally solved!!! no vib at all, no more need for filtering in the code...
Permalink Reply by Georges P. on August 9, 2012 at 7:10am How did you isolate board from vibs (what material)?
Could you send a photo to have an idea of your solution?
Thanks...
Permalink Reply by Flavio BSB on August 11, 2012 at 3:16am I still have this problem. Have to put APM in the box and fix it with double sided tape mounts. Please help us. If possible post a photo
Permalink Reply by Fabio on August 11, 2012 at 5:12am Hi,
I do not think the solution is to find suitable materials to isolate vibrations from the APM, with firmware 2.6.0 when there were no such problems. Why do not you do a downgrade on the Mission Planner to be able to fly safely, and allow time to correct the bugs of the 2.7.1 firmware.
Regards Fabio
Fabio, I suspect what may be happening here is that changes were made the to Alt_Hold code which makes it perform better, but also makes it more susceptible to vibration. So, vibration damping will help with 2.7.1. Really, it's something that should be done in any case, but this makes it more important.
Permalink Reply by Fabio on August 11, 2012 at 5:56am Hello R_Lefebvre,
We believe it is important to improve the stability and Alt_hold the road taken is correct given the evidence of the movies, but should not affect the stability, security of the vehicle. The bug is discontinuous and suddenly, bringing to the pilot error and creating a situation of difficulty in driving the quad.
Greetings
From my experience, the problem does not cause the copter to be difficult to fly. It's totally controllable. For me it's only an annoyance, or a curiousity. I just wondered why it started doing it.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.87 members
1280 members
7 members
179 members
16 members
Powered by
