When comparing a couple of I2C (digital) sonars with the normal (analog) sonars I noticed the range reported by the analog sonar appeared to be wrong. A tape measure proved the digital sonars were spot on and the analog data was well off. Other users have reported similar problems (here and here).
Some work with a spread sheet, schematics and the sonar data sheets helps point to the causes of this.
First the sonar module analog output is in proportion to the Vcc input to the sonar - this is a particular problem when running on USB where your Vcc can be down around 4.8 volts - you can not assume an accurate 5 volts to the sensor. This means you can not just measure the analog voltage output and hope to calculate an accurate range.
Second different Maxbotics sonar models output different voltages per centimetre. Even within the XL model range there is a 200% difference in output voltage for the same range. eg (from data sheets):
LV - EZ0 MB1000:(Vcc/512) per inch
XL- EZ0 MB1200: (Vcc/1024) per cm.
XL- EZL0 MB1260: (Vcc/1024) per 2 cm.
Third the analog port on the APM / IMU shield uses the ADS7844 external Analog to digital converter. This device does a 12 bit conversion relative to a reference voltage. The 'Foxtrot' version schematic shows this reference is 3.3 Volts. The ADS7844 data sheets says in this configuration it will digitize a signal in the range 0V to 3.3V. This appears to mean we cannot reliably use the sonars to their maximum range as they will output greater than 3.3 volts at some point (any range over 5 meters for the MB1200 and over 7 metres for the 1260). I wonder if this is why some users report strange 'zoom climb' behaviour when in altitude hold - particularly in the 4 to 8 metres altitude range.
The Rangefinder library makes no allowance for either of the three points above. It assumes the numbers coming out of the ADC are directly proportional to centimetres, and this is not the case at all. If you have a MB 1200 it will read twice the range of a MB1260 if you have a MB1000 then you have to convert from inches to metric and allow for half the resolution. If your power supply voltage (Vcc) is not known then you can not accurately calculate your range. If your sonar signal goes over 3.3 volts you may not get the correct result from the ADC.
Below is a screen grab of my google spreadsheet that shows the difference in reported range and actual range and the ability to calculate an fairly good adjusted range by taking the points above into account. I haven't tried this at longer ranges yet so cannot test the 3.3 Volt limit theory.
Before we charge off and re-write the Rangefinder library I'd like to hear what people think of the theories outlined above.
(for those that are curious the digital (I2C) sonars use timing of pulses to indicate distance so no voltages are involved and so they avoid all of these issues)
-Andrew
Tags: sonar
Permalink Reply by Tomas Soedergren on October 30, 2011 at 11:16am Uh. My ignorance almost make me blush.
I thought we were using the PW signal. Thats called whishful thinking, right?
Your findings are really very interesting @agmatthews, I hope this will be followed up.
I suppose there are good reasons for reading the analogue signal (hardware resources on ACM and Oilpan), but it certainly makes the data collection more vounerable. Depending on Vcc and sensitive to electromagnetic buss, which is inevitable among multiple ESC, XBee transmitter, and even worse for many of us, a high power video downlink.
Think I might dig into my boxes for some ferrite toroid...
Would it be possible and reasonable to develop I2C-option for the ArduCopter sonar?
Permalink Reply by agmatthews on October 30, 2011 at 2:22pm
Permalink Reply by Tomas Soedergren on October 30, 2011 at 3:11pm That sounds promising, Andrew!
Whats the pros and cons of the DIY vs the SRF02?
I could see in the spec for the latter that it has 6 meter range. One would hope for a little more, but rather 6 meter rock solid than 7,5 or 10 with guttaperka tendencies.
I hope you´re moving forward on this. Many will benefit from such an improvement!
ps. How about using same sensor as today, but reading PW signal instead of the analogue one? Difficulties?
Permalink Reply by agmatthews on October 30, 2011 at 3:38pm Tomas,
The DIY i2C sonar does use the same sensor as today (the Maxbotix MB1200 or MB1260) with PW signal. Have a look at this blog post for more detail.
It took me a while to translate 'guttaperka' - but yeah - on the bench the srf02 appears to be more 'rubbery' than the maxbotics MB1200.
I hope to do some testing on a day off tomorrow as we have a public holiday for a horse race!
Permalink Reply by MaxBotix Inc on November 2, 2011 at 8:07am Hi everyone,
We saw this comment and wanted to add some information. The MB1200 is the most sensitive sensor we sell and we believe it may be the most sensitiveness sensor for sale. We suggest testing the MB1240 and comparing it to the SRF02 because the beam pattern of the MB1240 matches the SRF02 best.
Also we recently tested the noise immunity of our sensor and want to ensure you have access to the information. Please click this link to view the post http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A2891....
If you have any questions, please let me know.
Best regards,
Scott Wielenberg
Technical Support & Sales
of MaxBotix Inc.
Phone: (218) 454-0766
Fax: (218) 454-0768
Email: scott@maxbotix.com
Great piece of info linked, as expected from a serious manufacturer.
However, I'm not sure (I don't say I disagree) suggesting the MB1240 (EZ4) over the 1200 (EZ0),
since although the noise immunity is higher its lower sensitivity may avoid tricky obstacles on the ground (ie: passing over a thin a metal fence:)
Sensor beams patterns liink
On the other hand you gave valuable piece of info on immunity to "acoustic" noise, but not to electrical noise (ie from ESCs), which is the most probable suspect of causing weird readings from the sensor (and maybe the sensor has not the fault but the signal wire picking noise from the sensor to the ADC)
Thanks anyway, you can never give too much info ;)
Permalink Reply by Andrew Radford on October 31, 2011 at 1:50am Yes unfortunately I think analogue is being used. Perhaps because it is easier to do it that way when it is on the Pitot port.Someone who knows the hardware should comment.
I've seen blog posts here which describe using shielded cable to reduce noise and that has a tangible effect on alt hold performance. However with PWM/Serial comms available from the Maxbotics devices I think we are really missing a trick here. It is always better to eliminate noise sources rather than reduce them.
Some one correct me and set the record straight if digital comms is working for sonar...
The question is if PWM or serial are available on APM hardware or maybe its less CPU intensive to use the external ADC.
However, anyone tried to use the sonar with 3V3 voltage and benefit from ratiometric properties (ADC and sensor same Vref)?
I see the point on using the sonar @5V and ADC "zooming" the usable 3.3V of its output, but voltage drifts and noise on 3V3 and 5V could ruin the desired precision.
I don't know if there is any suggestion about forum post but people (and I) could save huge amount of time if the post linked the datasheet and/or info page about the parts being involved:
Oilpan IMU(see schematic)
ADS7844 ADC
I agree with your conclusions:
- ADC readings will be clipped above 3.3V (@675.84cm with MB1200), but since this is more or less the max range of the sonar it's not a problem.
- The sonar is ratiometric (aka its output depends on its input voltage), so the most reasonable thing to do its to use the 3V3 supply (the same as the ADC's Vref uses) instead of the 5V, to null out any voltage drifting. (As done with accels and gyro chips)
MB1200 behaves almost the same using 3.3V instead of 5V, although slight less max range (6m vs 7M) and narrower beamwidth but, as the target is floor, I don't thing this is a major issue.
Permalink Reply by agmatthews on October 30, 2011 at 8:56pm I.S.
Yeah - I agree I could have linked to the datasheets etc - it was 1 o'clock in the morning when I was posting so please forgive me. :-)
You are right in that the clipped readings should be out near the maximum range of the MB1200 and the altitude calculation code (in arducopter.pde) also helps here it basically blends out the sonar data at 6 metres and uses the barometer from then on - no matter what the maximum range of the sonar is. (don't bother buying a 10 metre range MB1260 just yet!) Also because of the need to scale readings by approx 3.3/5.0 we are really only getting about 4 metres of sonar before barometer takes over. So in theory the ADC clipping is not much of a problem. In reality the behaviour of the ADS7844 is undefined when the signal (sonar) is greater than Vref (3.3).
if(baro_alt < 1000){
#if SONAR_TILT_CORRECTION == 1
// correct alt for angle of the sonar
float temp = cos_pitch_x * cos_roll_x;
temp = max(temp, 0.707);
sonar_alt = (float)sonar_alt * temp;
#endif
scale = (sonar_alt - 400) / 200;
scale = constrain(scale, 0, 1);
current_loc.alt = ((float)sonar_alt * (1.0 - scale)) + ((float)baro_alt * scale) + home.alt;
}else{
current_loc.alt = baro_alt + home.alt;
Permalink Reply by steve F11music.com on October 31, 2011 at 4:04am As a quick fix can I just put a ferrite ring on the cable until I can locate a shielded cable? Does it do the same thing more or less?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.47 members
24 members
87 members
183 members
692 members
Powered by
