I started off small with a custom built quad and got the hang of flying multicopters...This just fueled the fire. After doing much research, attempting to build everything from scratch and failing, I decided to start buying components for my hexa. (I've also decided that I need a CNC machine so I can build my own components/parts, so that project is next in line...)
My intentions at the beginning of this project were to be able to lift a camera (from gopro size to dslr size) to take video.
Here is a rundown of my copter...
frame: Hexacopter + configuration (mashup of different parts)
controller/autopilot: APM1
motors: 2210N 1000kv
esc: Turnigy Plush 30A
propellers: 10x4.7, APC SF
battery: Turnigy 3S 5000mAh
flying time: Currently unknown. Still tuning and working out the kinks. Will test shortly.
radio: Turnigy 9X
video/osd: eventually
other: Sonar, Xbee, Optical Flow, Attopilot current sensor coming soon
Misc:
Turnigy 9X: LiPo Battery
Camera Mount: x468 with mods (pics to come)
Supplies:
Boom Mount:
Motor Mount:
Power Disk (as I call it):
APM Mount:
Aft View:
Closeup:
Finished Copter:
Here is a quick video of my first flight. It hovers nicely at about 50% throttle. I still have to tune it and balance it out better, but not bad for it's first flight. I will also be checking flight times in the coming days. I'm also in the process of building my camera mount and will post pictures of that soon.
Tags:
Permalink Reply by BartJan Hooft on June 21, 2012 at 5:53am Hi there,
Like your build. I've just started working with copters and looking at building my own in a few months time. Where do you get your frame parts if I may ask? I am interested in your arm mounts and and roto mounts?
Further were did you get your gimble and landing frame. If I may ask what did you spend on such a build in total and what can this thing carry in weight?
Look forward to hearing from you. Beej
Permalink Reply by Andrew Adams on June 21, 2012 at 8:14am I got most everything from here. They aren't cheap, but it's a high quality product and very sturdy. I wanted something that was sturdy, strong and didn't have that DIY look.
The Camera gimbal is from x468.com
The landing gear is from AGL Hobbies
I don't even know how much I've spent and don't want to think about it...If I had to guess, the frame, camera mount, landing gear, motors, wire, escs, hardware and batteries cost me over $500.
As for how much it can lift..I'm not exactly sure. I haven't tested it. It weighs in at right around 2kg if I remember correctly. The motors aren't the best and could be upgraded for better performance, but I can lift off and hover with my Canon G12 camera at around 50% throttle.
Hope this helps!
184 members
51 members
8 members
51 members
Powered by
