Given some of the horror stories of people losing quads I'm determined to be completely across the failsafe settings in APM2 so i've read most of the threads but after doing some testing I have one question.
I removed the props, dialled up the throttle (in stabilize mode) and switched off the transmitter and as expected the APM2 doesn't detect the loss of signal and remains in stabilze mode. So i updated the PPM encoder to .68 and now after dialling up the throttle and switching off the transmitter it transitions to RTL straight away however sometimes it then transitions to loiter.
How come it doesn't just stay on RTL?
I haven't actually moved it from the spot that I armed it, would that be way it changes to loiter?
Tags:
Permalink Reply by Jake Stew on June 19, 2012 at 8:18am That's how RTL is supposed to work. It returns, then loiters.
and after a certain time, may do an AUTO LAND too.
So it is Failsafe -> RTL -> LOITER (once overhead) -> 30sec -> LAND
That gives you time to re-establish contact while above you in LOITER, or it lands.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
24 members
246 members
1277 members
179 members
Powered by
