Antenna Tracker
I found this website with a Antenna Tracker for RC flying. They say it will be ready in April.Antenna Tracker:- Essential companion to the EzOSD- Uses real-time telemetry from the OSD to keep an antenna pointed at a model.- Two axis guidance, using standard pan/tilt mounts.- Greatly increases range for CE-compliant European video gear.Availability: April 2009http://immersionrc.com/products.htmAre there any othere options out there if you wanna have a Antenna Tracker for your FPV or UAV.
EzOSD w/Telemetry and Antenna Guidance from ImmersionRC on Vimeo.
