Hey all,
I have been having trouble determining the antenna tracker parameters for the APM Mission Planner. I have gotten it to work within the Pololu Maestro software with the parameters:
Pan (HS-785HB):
Min: 1312, Max: 1584, Startup: Goto 1450, Neutral 8-bit: 1448, 8-bit Resolution: ~136
--Setup so that it can rotate +- 180 degrees from "neutral"
Tilt (HS-645MG):
Min: 1584, Max: 2200, Startup: Goto 1976, Neutral 8-bit: 1892, 8-bit Resolution: ~308
--Setup so that it can rotate from straight forwards (parallel to horizontal) to straight upwards (parallel to vertical).
Serial Settings:
USB Dual Port
My problem is three fold:
1. Which port do I use to communicate with the Maestro? The Command or TTL port?
2. What baud rate should I be using?
3. What numbers should I set the angle and PWM parameters to, within the mission planner?
Thank you in advance for your help.
Hi All,
What APM version are you using (2.0 or 2.5)? Also are you using an external GPS, if so....which one? The reason I ask is because I'm using APM 2.0 with the internal GPS and the latency is slow on the tracker plus the plane is not exactly showing the correct location in the planner on MP while walking the plane around (30-60 meters away). So my plane setup seems to have some interference going on and I think it's the GPS, maybe the 3DR radio with my 433mhz RC transmitter, or all three. Any ideas or others having similar issues?
I'm about to try an external GPS, but just thought I would ask the community.
-Taylor-
Hi All,
I am having a weird issue - the setup works well as described in the treads, but only in Maestro config utility.
The APM says its connected to the Maestro on the correct com port, but can't get any movement out of the servos despite the same range, centre and angles configure.
What am I missing?
Bernhard
Hello,
I have ordered all the necessary components to assemble my tracker and am familiar with all the configuration but I have two questions about using the Mission Planner that I can't find clear documentation of. In the screen shot below there is a button labeled 'Find Trim Pan (3DR Radio)', what does this do and how do you use it? I haven't been able to find any documentation on it's use or function. I am assuming that it uses your RSSI to derive the location of the aircraft's starting or home location?
The second question is related and has to do with setting up the antenna. I know the antenna base is supposed to be pointed North, but I didn't see a clear answer to the question of weather or not that was true or magnetic North. Also do you then point the antenna at the plane's home position using trim as above?
Nathaniel ~KD2DEY
Hi William,
I was wondering if were able to solve your problem? I have the same exact antenna tracker as you with the same servos. I was wondering if you finalized your settings and could possibly share them.
-Chris
I'm very glad I found this thread. I have followed the following guide to the letter:
http://code.google.com/p/ardupilot-mega/wiki/AntennaTracking?ts=134..., but I'm not having much luck.
My setup is the HSHS-645MG servos for both pan and tilt. Pololu Maestro 6 channel servo controller.
This results in a reliable 180 degree radius turn (90 degrees both side) and 90 degree tilt. I'm using the readmaderc.com hardware setup (pod).
Tilt seems to work OK, but pan is a complete mess. My calculated values are:
pan: min 1120, max 1888, 8bit range 384, pwm range: 768. MP set to 180 degrees
tilt: nub 1988, max 1877, 8bit range 394, pwm range: 789. MP set to 90 degrees
Neutral range is set to 1500 in both cases.
Now, my other problem is as follows: the wiki states to always point the AT North. Then set the tracker home location (in the Flight planner screen). The problem is that at my house, the 'home' location of the drone is at 90 degrees (East) of the tracker home location: in other words already at the max right movement.
What I really like is to point the antenna at the drone's home location so that it has 90 degree left and 90 degree right turns available.
Also, because tilt's center is 45 degrees, I need to trim the tilt to horizontal. Is that correct?
Any help would be greatly appreciated!
1. try both... only one will work.
2. any, it auto detects.
3. have you followed my guide?
the neutral value should always be in the middle of your range.
