Antenna Tracking using Pololu Maestro
I have just finished building an antenna tracker and am trying to get it to work with mission planner,
I have the servo's and movement setup in Maestro but mission planner will not connect to the servo board I keep getting this error.Have all the drivers installed in xp and can control the tracker manually using the Maestro software.Any help would be great thanks.
3691080867?profile=original
  • When you connect Maestro board to PC You should get 2 serial ports available - try to connect to both. One of them will work.
