Anyone trying to connect xbee with mission planner???
Hello , Please Help!!!!!!!!!!
I am trying to connect xbee xb24 with mission planner. I succesfully configure the two radios via xctu soft , and the two radios are communicate perfectly. After that i open the mission planner and check that i have the same comport , same baud rate and from initial setup /3dr radio page push the ''Load settings'' button after some wait i receive '' Failed to ener command mode''. If i try to connect with the radio on the apm2.5 after 30s ''No Heartbeat Packet receive''. Is there something i missed? I notice that when i am trying to Load settings the mavlink trying to send the following commands ATI AT&T , ATO wich is not recognized by the xbee module.
  • Hi,
    Not much help at the moment. But last time a tried I had this issue. My Xbee worked fine with droid planner on my tablet, but it stopped working on mission planner on my desk top. I will try and do a retest. I have since got my old laptop going again (battery needed replacing) and it has an old version of mission planner installed, update and see if it stops.
    I asked a while back, but didn;t get much of a point in the right direction.
  • Can you connect via USB without issue ?
    If so, what are the rates for SR0_* and SR3_* in advanced parameters ?  Screenshot could be useful of this page.
