I have attempted to find information in regards to connecting an onboard computer to an APM (1.0 or 2.0), however I have found disjointed information. I need to know if it is exactly possible to send commands to an APM via serial from a separate board (Intel Atomboard running Linux) that is on an ArduCopter? Is it possible through the USB port?
I found some threads discussing sending commands, but most seem to be through the Base Station. I did find commands on the wiki, but am not sure if those are also through the Base Station. I also found some people mentioning the XBee for connection which is equivalent to what I will be doing through Serial. Finally I found some possible avenues through ROS, but again, am unsure of what the connection is through.
In other words, I believe what I want to do is completely possible and think I have found more than enough information, but before I make a final choice, I just want to see if anyone can confirm my results.
Thanks for your help.
Tags:
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.58 members
1355 members
88 members
24 members
207 members
Powered by
