In a APM2.5+ purchased in December 2012 I installed the latest driver "ArduCopter-2.8.1.zip" in the "APM 2.5" using the Mission Planner desktop utility ("MissionPlanner-1.2.29.msi").
The system does not work. After installing the latest driver and connect to Mission Planer desktop will not let me set it up.
Through the terminal I did a test of all sensors, all are correct, except for the case of the pressure sensor (MS5611-01BA03), which does not show any results,enclose a copy of the screen.
Tags:
Permalink Reply by Peter Chaffe on January 10, 2013 at 5:08pm I didn't quite understand what your saying..
Go to firmware, install FW of choice.
Then to set it up you need to connect...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1298 members
87 members
693 members
7 members
48 members
Powered by
