Hi everybody
I had encountered a serious problem yesterday. When I switched to RTL on CH8 at 13:08:34, then the multicopter started to roll on the right side. Don't know why how it happened. I had performed RTL function over 5 times. It should be fine I think. Can anyone tell me what's wrong? I have no idea of it.
Any suggestion will be very appreciated.
Lo
Airframe: Hex
Model: APM 2.6
Firmware: V3.1.5
Optional hardware: 433MHz Radio Telemetry
RC Transmitter/Receiver: Taranis X9D 2.4G / X8R
Ground Station: Mission Plannner 1.3.10
LogAnalyzer
Log File C:/Program Files (x86)/Mission Planner/logs/Download_From_APM2.6/2015-01-03 12-59-56.log
Size (kb) 1021.0810546875
No of lines 14692
Duration 0:08:42
Vehicletype ArduCopter
Firmware Version V3.1.5
Firmware Hash 3c57e771
Hardware Type APM 2
Free Mem 982
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: CRASH
Test: GPS = FAIL - Min satellites: 4, Max HDop: 8.63
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = FAIL - Roll (164.83, line 14517) > maximum lean angle (45.00)
Test: Thrust = GOOD -
Test: VCC = WARN - VCC min/max diff 0.321v, should be <0.3v
maybe I'm too late but I would blame this line:
With this high HDop value and that low number of satellites it is definitely not recommended to use any GPS based flight modes.
Chris
