APM 2.6 Fails to download parameters
Hi there!
1.My APM 2.6 is not downloadind params stopping/hangs at 'PARAM RC4_REV'
2.Please require urgent advice,(used the APM 2.6 only once on my Bumble Bee Quad)
        warm regards
  • I must admit that I am also having issues with APM Planner and communications with the last version.
    2 different computers, 2 different copters and the link keeps randomly dropping out.
    Maybe this is the issue and not the APM after all.
    • I can not get APM Planner to work at all on my laptop only been using mission planner...
      I've been doing some more testing and it seems if I disconnect everything but the GPS-Compass all
      works fine, but when I connect the RC receiver that's when I seem to start locking up. I think I've narrowed
      it down to the receiver whether I have it wired incorrectly or something in the receiver wrong not sure.
  • I have had this fault in the past and found if I reburn the firmware it went away.
    I put it down to fault in the original firmware installation
    • Hi Mike,
      Thanks for your input,so finally what is the way out how do I get my APM 2.6 back on track?
      Is reset is the option if so how do you do that?
      • Mission Planner/Initial Setup/Load Firmware
        • Tried that many times but no joy!
          • UUUUggghhhhh i have a similar issue APM 2.6 lock up on firmware upload. Mission planner
            freezes up just not having a good time with it right now getting frustrated....
