Greetings all,
I have been trying to build a fully autonomous, indoor drone for about year now based on the Owenquad Tutorial (https://code.google.com/archive/p/owenquad)
I am using a ardupilot apm 2.6, F330 DJI Flamewheel frame, Emax 2212 motors, Emax 20A ESC with SimonK firmware, 8045 props (8"), and 4 Lipo Cell Battery.
The problem is the stabilization does not make any sense, when trying to hover. It always wants to fly forwared and sometimes right. I have made sure the quad's weight is balanced and I started with very low PID values, but adjusting the PID values makes absolutely no sense because I enter values as low as 0.00000000001 and it will still move right or forward.
Like I said, I have been working on this for a very long time and I am at a lost. What could I possibly be doing wrong or is there something wrong with the owenquad code (Here is the code: http://owenson.me/build-your-own-quadcopter-autopilot/pi-quad.ino).
Yes, the ardupilot is oriented correctly and yes the ESCs are calibrated.
If someone helps me figure this stabilization issue out I will give them $100, via paypal and if you are in the bay area I will also buy you a beer. Thanks in advance!
it's leveling that helps it "stand still" in an non-navigation mode.
no multirotor/helikopter will "stand still" whithout having position reference and correcting position according to it.
so It's in stabilize or alt-hold mode, you should not expect it to hover perfectly still.
if it gains speed towards one direction every time, (no wind, in open space) : do "accelerometer levelling"
Hi Andre,
Thanks for the suggestions. There is a line of code to calibrate the accelerometer, when ever the drone is powered on.
I actually met a really helpful guy at a Hobby People store that found the problem.
The issue was that we needed to create a software equivalent of "Trimming" that is done with the trimming buttons on a RC controller.
Just an FYI for anyone that encounters this problem. After all this time it was a simple adjustment. I should have asked for help a long time ago...
