0 APM 2.8 with Spektrum AR7700 Posted by Dave Mauger on December 18, 2015 at 5:21pm With the new Spektrum AR7700, where does the lead from the PPM port on the receiver go to on the APM 2.8 board? You need to be a member of diydrones to add comments! Join diydrones Email me when people reply – Follow
@Dave,
If the PPM output of the AR7700 is similar to the 3DR PPM encoder, then I would connect it to the APM just as if it were the 3DR PPM encoder.
I am attaching a pdf file that provides instructions on how to attach a PPM encoded signal to the various 3DR flight controllers.
The Spektrum AR7700 Overview says that it is compatible with the APM2.6.
Make sure that the signal, power, and ground connections are the same from the APM to the receiver PPM output.
TCIII AVD
PPM-Encoder-V3-Manual.pdf
