I was curious how to interface with the RVOSD current sensor. It puts out 12 volts and I dont know how that would work with the APM 2. Im pretty sure the signal is analog but I dont know the signals voltage range(0-3.3v or 0-5v or 0-12v ?) and Im unsure how to test it since its voltage is 12v and the APM is 5v. Im pretty sure the sensor would fry the board. I cant seem to find any specs on the sensor. Has anyone tried this before?
Thanks,
Daniel
Tags:
Permalink Reply by Mike Mandziuk on May 28, 2013 at 7:49pm I know this is an old post but I was thinking if you knew for sure that the output was proportional and was no greater than 12 volts, just a couple of high-value resistors would work for example
+ ------------ 70k resistor-------------- +
12 Vsensor | 5 volt sensor input
output 50k resistor
Vout= 50/(50+70)*12V
this wouldn't fry your input.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.58 members
1355 members
88 members
24 members
207 members
Powered by
