Is there a away to connect the servo to apm? i would like to use the gyro inside the apm. so that it able to move the servo when the apm move. something like stabalisation
any one help pls.... i really need help. anyone will do
Tags: apm, codes, connect, gyro, help, motor, move, need, servo, stabalisation
spaces in library and include paths. I have no idea why software written to work with VS on an MS platform would neglect to handle spaces in paths correctly, given "Documents and Settings", "Program Files", "My Documents", "My Projects", and so many other default folders and paths with spaces, but that is your best bet. I'm sorry, I cannot help further with this VS/VM software. I recommend using the Arduino IDE. I have a Mac. Good Luck.
It means that i must used all the programe for arducopter? You able to do it?
Hey im aasking. Im using arduino IDE.  Do u know where it keep the librari files?
Is it on 'documents' or is it on the other folder? 'Like arduino 0022'
See http://code.google.com/p/arducopter/wiki/Quad_LoadingPage
Look for "2. Setting the Arduino Sketchbook folder"
There have error when im using arduino IDE. I think it cannot be solved.
Do you know how to solved it? The error is about
 error: 'comm_get_txspace' was not declared in this scope
and many more other error. Can you help?
