I built a TRex 450 with an APM mounted as suggested by Randy but am thinking about changing it and mounting it in a different way that would result in the APM being upside down.  My question is, can I easily correct this by modifying the code?  Is it just a matter of changing the sign for a number of the signals?  I noticed there is a config parameter for changing the orientation of the magnetometer, but I didn't see anything for the orientation of the APM.
Tags: apm, arduino, ardupilot, mega, orientation, t-rex, trex
Graham,
     There's no easy way to do this I'm afraid.  It's definitely possible though but you'd need to modify perhaps the AP_IMU_Oilpan.h file in the AP_IMU library or maybe somewhere in the DCM lib when it consumes the accelerometer and gyro data..but I can't tell you exactly what you'd need to change.  If the APM is upside-down I think you need to reverse the pitch gyro values and all three (x,y,z) accelerometer values.
Thanks for this Randy. I am going to try and see if I can make it work and I'll let you know if I am successful.
It looks like I found the spot and it is much easier than I had thought. I am planning on changing the signs as needed to compensate for the flip. Does this makes sense? Do you think there will be other places in the code that I will need to correct? Or is it really this easy?
// Sensors: GYROX, GYROY, GYROZ, ACCELX, ACCELY, ACCELZ
const uint8_t AP_IMU_Oilpan::_sensors[6] = { 1, 2, 0, 4, 5, 6}; // Channel assignments on the APM oilpan
const int8_t AP_IMU_Oilpan::_sensor_signs[6] = { 1,-1,-1, 1,-1,-1}; // Channel orientation vs. normal
Ah nicely done.  Yes, that makes sense and that might very well be enough.  I think normally in the rest of the code we use DCM which has already processed the sensor values.
I got it working upside down! For the record, this is with the pins facing towards the back and the APM with the components facing down. Here is the line I used:
const int8_t AP_IMU_Oilpan::_sensor_signs[6] = { 1,1,1, 1,1,1}; // Channel orientation vs. normal,
I flipped GYROY, GYROZ, ACCELY, ACCELZ. Perhaps we can add a configuration to make this easier for other people in the future. For now I am going to focus on getting it flying and make sure it all works as I expect.
Congrats!  well done!
Yes, great stuff!  Just made this mod to mount an apm1 under my 3DR frame.  Works tremendously. :)  The filename has changed but grepping on GYROY etc will turn it up.
