Hello,
I'ld like to share with you a bug, maybe I it's not..?
When I Clik on the green button ("First Time setup") after a successuf upload
of the Hexa Arducopter configuration... It seems that the APM freeze.
On the board, linked by USB, the green led is flashing and the orange RX led Also.
But nothing happens (it seems)
Can you advise me please ?
I really want to fly my hexa :)
Thanks for help :)
Tags: APM, bug, first, hexa, planner, setup, time
Reset, restart the Mission Planner and try again.
Make sure that you've got a LiPo plugged in to power the RC:
http://code.google.com/p/arducopter/wiki/AC2_ConfigRadio
Hello Chris,
Thanks a lot :) It works ! ( I don't understand one more thing ... Why I see only 5 motors run ?
That is the radio config (APM planner):
And that is the strange response for full Throttle :
If I follow the HEXA config, So Output 7 and 8 should run .... (8 is ok, this output respond correctly with the other 1,2,3 and 4) But 7 ... Big mystery ...
I've configured my radio like this :
  • CH1 (Ail)
  • CH2 (Elev)
  • CH3 (Throttle)
  • CH4 (Rudder)
  • CH5 (Switch 2 positions)
  • CH6 (Switch 3 positions)
  • CH7 (Switch 2 positions)
Thanks for any advice.
This is because hexa setup motor output is not yet implemented in the mavlink protocol. It does only affect radio report window i think.
It should be here in a few days i think, as i ever exchanged some words about this problem with the development team a couple days ago.
It is not something hard to correct, just a couple lines of missing code.
Thank you and good luck :)
