Hello Everyone,
I'm trying to run a simulation using X-Plane to get comfortable with the RC system. I'm unable to get an output graph for the servos in APM Planner, even though the servos are connected through APM and they move when I move the sticks.
I have done the radio setup and mode setup with arduino-ide in CLI. I'm running APM 1.02, I have the APM 1.0 board with the OilPan. I'm using 3 servos, a battery is connected to the RX which powers the servos and a USB connection is present. I've also followed the steps in the manual (http://code.google.com/p/ardupilot-mega/wiki/Xplane) for the settings in X-Plane.
1 - My question is what am I missing? I can't get any responses from the TX in X-Plane, nor in the Planner.
2 - Is it normal that APM does its sequence of calibration everytime I try to connect and disconnect from ArdupilotSim or read from the EEPROM? I don't remember it doing that before.
Here is a copy of my:
APM_Config.h
READ THIS. REALLY! READ THIS.
First, you MUST uncomment the GPS PROTOCOL line below or the code will not compile.
This is because we need you to tell the code which GPS module you're using, so we can load the right libraries.
Second, there is a lot more you can do with configuration options is you want. See the APM manual for all the available options.
//-------------- REQUIRED ------------------
#define GPS_PROTOCOL GPS_PROTOCOL_MTK16 // You must uncommment this line by removing the slashes ("//")
//in front of the "#" and select either the default (GPS_PROTOCOL_MTK) or one of the following other supported GPS modules if you're
//using one of them instead:
// Other allowed options include:
// GPS_PROTOCOL_NONE No GPS attached
// GPS_PROTOCOL_IMU X-Plane interface or ArduPilot IMU.
// GPS_PROTOCOL_MTK MediaTek-based GPS.
// GPS_PROTOCOL_MTK16 MediaTek-based GPS with 1.6 firmware
// GPS_PROTOCOL_UBLOX UBLOX GPS
// GPS_PROTOCOL_SIRF SiRF-based GPS in Binary mode. NOT TESTED
//----------------OPTIONAL-------------------
#define GCS_PROTOCOL GCS_PROTOCOL_LEGACY
// The GCS_PROTOCOL option determines which (if any) ground control station
// protocol will be used. Must be one of:
// GCS_PROTOCOL_NONE No GCS output
// GCS_PROTOCOL_STANDARD standard APM protocol
// GCS_PROTOCOL_SPECIAL special test protocol (?)
// GCS_PROTOCOL_LEGACY legacy ArduPilot protocol
// GCS_PROTOCOL_XPLANE HIL simulation ground station
// GCS_PROTOCOL_IMU ArdiPilot IMU output
// GCS_PROTOCOL_JASON Jason's special secret GCS protocol
#define GCS_PORT 3
// This determines which port APM will send telemetery on. The USB port is Port 0, for when you're testing on the ground.
//The Xbee port is Port 3, for the field and in the air and you want to send telemetery wirelessly
#define SERIAL0_BAUD 115200
#define SERIAL3_BAUD 57600
// These determine the baudrate for the telemetry port. Default is 115200bps for Port 3.
//#define AIRSPEED_SENSOR ENABLED
// Are you using an airspeed sensor? Choose DISABLED if not.
//This section is in charge of software simulation with Flightgear
#define HIL_PROTOCOL HIL_PROTOCOL_MAVLINK
#define HIL_MODE HIL_MODE_ATTITUDE
#define HIL_PORT 0
#define GCS_PROTOCOL GCS_PROTOCOL_MAVLINK
//#define GCS_PORT 3
APM_Config_xplane.h
#define FLIGHT_MODE_CHANNEL 8
#define FLIGHT_MODE_1 AUTO
#define FLIGHT_MODE_2 RTL
#define FLIGHT_MODE_3 FLY_BY_WIRE_A
#define FLIGHT_MODE_4 FLY_BY_WIRE_B
#define FLIGHT_MODE_5 STABILIZE
#define FLIGHT_MODE_6 MANUAL
//#define GCS_PROTOCOL GCS_PROTOCOL_DEBUGTERMINAL
#define GCS_PROTOCOL GCS_PROTOCOL_XPLANE
#define ENABLE_HIL ENABLED
#define GCS_PORT 0
#define GPS_PROTOCOL GPS_PROTOCOL_IMU
#define AIRSPEED_CRUISE 25
#define SERIAL0_BAUD 38400
#define THROTTLE_FAILSAFE ENABLED
Thanks for your help.
Tags: IMU, code, help, oilpan, rx, servo, settings, setup, simulation, tx, More…xplane
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
24 members
1283 members
180 members
4 members
Powered by
