Hi Everyone.
I'm using a Spektrum DX8 with an AR8000 receiver. It's setup for 6 flight modes and I did a binding to a Failsafe Preset. If I hookup my hexcopter to Mission Planner and shutoff my radio, I can see in Mission Planner that:
1) My throttle goes to 926us
2) My flight mode goes to RTL
However, after getting all this working, I took it out to the field, waited for GPS lock, then lifted off about 3 feet and landed. Then I left the props running at very low speed and carried the hexcopter to a new position about 300 ft away. At the new position, I verified that I was still armed (by lifting off a couple feet), then landed but left the props running on low (so APM2 would think it was still flying). I then shut off my radio. The props immediately quit running. After a few seconds, I turned my radio back on and was able to take off without re-arming --- so the hexcopter was still armed... but RTL never caused the Hexcopter to Return to Land.
I brought it home to look at the logs, but are basically empty, so they were not any help.
Reading the forums, I've not run across any steps I've left out, but there must be something I'm doing wrong.
Any ideas?
Thanks,
Dustin
Tags:
Permalink Reply by Vernon Barry on June 25, 2012 at 6:43pm First, test failsafe with the props off, never the way you just tested. The problem is, if the TX is off, you have no control and thus that spinning blades could have become your worst nightmare. Shame on you and consider yourself lucky. You could have easily determined the functionality with no props and a lot less danger.
There is a known "feature" of the PPM encoder that too low of a signal on the throttle while the other channels remain valid or centered results in the PPM continuing to send the last known good throttle signal. Being that you were idling, shut off the TX causing the RX to go failsafe, either the throttle was low and remained low, or the other option was the TX dropped all outputs to zero and the PPM then dropped out so you didn't seem to activate runaway mode, but again, that's why I'm warning you since likely, you are going to be playing with settings and that's a very real possibility. If you hit the magic setting (and trust me, by having it idling and then turn off the TX, that's as close as you ever want to get to the exact situation known to cause a runaway).
http://code.google.com/p/arducopter/wiki/Failsafe
http://diydrones.com/profiles/blogs/spektrum-dx8-and-ar8000-failsaf...
Permalink Reply by Dustin on June 25, 2012 at 6:45pm lol... I wasn't foolish. I put foam props on for the test.
I've read both of those links in getting my system setup. The second link covers how to get the throttle to show a value below the 975us threshhold.
In rereading the other link, it could be that I am essentially triggering the wrong failsafe --- ie. I don't think I need the low throttle failsafe because I have the receiver failsafe working. I'll look over them again, thanks.
Permalink Reply by Vernon Barry on June 25, 2012 at 6:51pm Cool, I just had to look at it that others might not remember that step.
Anyway, hope those links help.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
1278 members
182 members
24 members
51 members
Powered by
