My APM2 says "no dataflash inserted" when in terminal.
does it need some sort of formatting or anything else to be recognized ?
Tags:
Permalink Reply by entropia666 on April 29, 2012 at 2:46am I have the same problem here, yet the SD is inside the sock...
I have the same problem , triyng to download logs, what is wrong?? no anwers?
Permalink Reply by Sam on August 6, 2012 at 7:52am remove your dataflash card. Power up the APM2.0. Let it set for a few seconds. Disconnect the APM2.0 from the power source. Insert the dataflash card. Power up the APM2.0. It will re-format the card and should work properly after a few minutes.
Permalink Reply by Bjarni on November 4, 2012 at 3:53pm I know that you instructions sound very simple and straight forward, how ever I have tried 5+ times to reformat my SD card by simply connecting the APM 2.0 to my computer with the USB cable (to power it) at let it stay for 5-10 minutes but there is nothing happening... is there a youtube video somewhere of someone reformatting his dataflash card? just so it is crystal clear what to do, because I find it strange that it should automatically formatt the dataflash card by simply connecting power to the board and wait :) should there for example nothing else be connected to the apm (such as servos and receiver) there must be some more magic than just power it up and wait :) or what? Thanks ;)
Permalink Reply by John Mulligan on August 6, 2012 at 8:19am I found the flash card did not make good contact with the socket. This caused no data flash inserted errors and failure to boot errors.
I placed a small piece of electrical tape on the back of the card and eased it into the socket, the added thickness fixed the integrity with the contacts.
Permalink Reply by Mike Mac on August 25, 2012 at 5:34am My APM works ok but it does not log anything and gives an error in the terminal mode. I don’t use logs so it’s no big deal for me. I get all my information from TM.
This is a common problem with APM2.0 and the 'extra thickness' tape is one solution.
I burnished the card contacts (not the onboard connector) with an eraser, lightly, to resolve my 'lost flash' issue.
APM2.5 has a better/improved flash card socket.
-=Doug
Permalink Reply by Zafer Öznalbant on April 17, 2013 at 7:43am Hello there. I have the same problem with my APM 2.0. I did both ways to start my dataflash card but it didn't work. I put some extra thicknes backward of the card but it didn't work. I also powered the board without dataflash card then re-power after put it back but it didn't work either. What can I do?
zafer
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
682 members
1288 members
182 members
83 members
Powered by
