Ok this is a double post - but couldn't find that ONE subject specfiic to this issue or query.
...Not sure what the go is, as I have been using GPS devices for many years, I developed a tracking system with Franson many years ago and use SANav devices, and leadtek, and even Nokia...all have fantastic GPS pickup, but the Mediatek onboard seems a little insufferable.
I have seen so many suggestions of "unplug your receiver" and remove your ESC, etc...but if these are all solutions by the time I'm finished the only thing that will be in the UAV will be the APM itself - it can't be a solution to remove all other electronic equipment just to get the GPS to pick up more than 2 sats.
OK - a bit of ranting there, but then that being said early on in the evening (I'm guessing it was before the clouds rolled in.) I did have good sats (6 I think.) and was getting to within 3-4 metres without much drift...interestingly right before I got nothing I started to see my plane icon in mission planner slowly creaping north until it was over the back fence of the neighbour across the road.  Althogether not to bad really...But I suppose the reason I am posting this is...HAS ANYONE...managed to increase the pickup ability of the Mediatek GPS - whether onboard or offboard by changing the antenna...
What I've seen is every manufacturer is SO very proud that their GPS is smallest on the market with small Ceramo-helical GPS Patch antennas smaller than my thumb.   But the reality is I am not THAT void of space that I can't afford a few more mm for a bigger antenna.  SO my question really is, is there any merit or harm in creating an external antenna to attach to the GPS module...and if so does anyone have any plans/calculations like iBcrazy's CL and SP antennas...
I would be fine to hack the APM case a bit - or do without it, de-solder the current GeoHelix Ceramic antenna and install an aluminum pie-plate if need be...Just Gimme those Satelitttttttesss....
Tags: 10hz, Antenna, GPS, Nolock, Satelites, fix, sensitivity
