APM2 GPS Red LED and data help (CRASH REPORT, ANYONE ELSE?)
HI everyone,
I have been struggling with the APM2 that I have just installed and have been trying to fly in Auto and RTL modes. I do have the plane flying great in the stabilize mode and the fly by wire mode also works.
When I switch the plane to RTL or Auto mode the plane does fly itself (circle) and hold altitude but it does not go to the waypoint locations and it does not circle over the home or launch point. Every time I have flown I have waited for the blue led to go solid and also the 3Dfix led is solid. I have also connected to the computer outside and in the mission planner it says 3Dfix. I do NOT ever get a red led to stay on. The red led does flash when the board is first powered up but then has never stayed on solid like is says it is supposed to. See the link.
http://code.google.com/p/ardupilot-mega/wiki/LED
That brings be to my next problem. It was suggested to me to look at the data log and see if there is an actual gps lock. When trying to look at the data log in the mission planner I do not see any horizon changes, speed or altitude changes. It does say the log is playing but I am unable to see any of the planes functions.
I have been struggling with this for a week now and do not know what to try next. If anyone could give me some suggestions that would be greatly appreciated.
Ryan
Tags: 3Dfix, AMP2, GPS, Red, data, led, log
can someone pl tell what color light means what, i have the apm2 and i find there r 4 lights, if it can be elalorated that this colour is .........,    solid means ....,      flashing means this......, i will be really greatful, i could not find in anywhere .
Here is a link to the light info.
many thanks Ryan
A stupid question but i must ask, once i plug the usb cable between APM2 and my PC and i have down loaded the Quad program from mission planner, i could not find anywhere the option to disconnect/eject  the APM2 from my pc. So i just unplugged it. Will this damage on board memory of APM2 or is there a way to unplug the usb cable from a pc......
second question, is the Quad option only in the + mode or is there a way to use the X mode, cause in the mission planner i could only see one option for quad, the PLUS mode, that means one motor points in the front direction, cause i have made my quad as a X and will have to make the base plates again to re-orientate to the + type......
Not a stupid question. I have been clicking the disconnect button in the mission planner before I unplug it. But as far as ejecting the usb connection I am not aware of any way to do it.
I am using the APM2 for the first time myself so I would be happy to hear if there is another way to do it.
I was planning on getting the telemetry kit to do it wireless but have not been able to get the APM2 working yet so I am not to interested in dumping more money until I see something work.
Hi Ramesh,
I do not think it's necessary to have a way to 'eject', as there will never be any delayed-write data to be sent to the device for storage or open files to be closed. Just unplug and go  :)
John,
many thanks. i have absolutely no tech knowledge about all this, so will keep asking silly questions and hope all u guys will have patience to take them on....
Does anyone have a video or You tube video of planning a mission for the APM 2. I am hoping I am doing something really stupid wrong here. Last night again I hooked up my computer to the APM and the GPS found my location with no issues. Everything looks right to me but the plane will not hold a location in RTL ( or even go to a consistent location ). Also it will not go to waypoints that I write to the APM.
I am wondering if this is a software problem not a hardware problem.
Also I did send a email to help@3drobotics.com but have not heard back yet. How long does that usually take?
Anyone that can help I will be in your debt
Ryan
Hi Ryan,
I had APM 2 in my Bixler and worked great - Missions RTL etc - very cool. I then put it in my quad but it wasn't very stable so I will wait for some stable code. I have put it back in my plane and am now having the same problem as you. MP tells me home is spot on - I reset home - Wait for 8+ Satellites, push reset, wait a minute more to ensure HOME is set, and it just flies off into the ether circling away???
Not sure mate. I don't get the red light on Arduplane, but do on Arducopter.
Just keep plugging away
Thanks for the reply. Hopefully today I will get some time to try it out again. Since my last flights I have uploaded firmware for heli's and quads and now re-uploaded the plane firmware. I also am using a different computer with the mission planner installed. I am going to erase all the data logs in the APM. My first test will be to walk around with the plane in my hands and watch the GPS light and ensure it stays on. Then I will check that data log. If I am unable to read that data log like the others I am probably going to send it back.
If that data log works I will continue with the testing with flights.
No more messing around with this for me:))
Ryan
Ryan,
thanks again, i have unzipped mission planner, but i find that there is no shortcut icon on the pc desktop screen, so does it mean i have to go to the .exe file every time i want to go to mission planner ????
if i have hooked up the APM2 to the pc and downloaded quad codes, now if i hook up again and download again, will it over-write the previous download, or do i have to erase previous from APM2 before downloading again ???? and if i have to erase before downloading again how do i erase.???
Also, if i now want to download codes for say aeroplane or car, then do i first erase previous codes before downloading new codes for another type of machine ???? of do i just click on appropriate icon for the machine and mission planner will do everything.....
