HI everyone,
I have been struggling with the APM2 that I have just installed and have been trying to fly in Auto and RTL modes. I do have the plane flying great in the stabilize mode and the fly by wire mode also works.
When I switch the plane to RTL or Auto mode the plane does fly itself (circle) and hold altitude but it does not go to the waypoint locations and it does not circle over the home or launch point. Every time I have flown I have waited for the blue led to go solid and also the 3Dfix led is solid. I have also connected to the computer outside and in the mission planner it says 3Dfix. I do NOT ever get a red led to stay on. The red led does flash when the board is first powered up but then has never stayed on solid like is says it is supposed to. See the link.
http://code.google.com/p/ardupilot-mega/wiki/LED
That brings be to my next problem. It was suggested to me to look at the data log and see if there is an actual gps lock. When trying to look at the data log in the mission planner I do not see any horizon changes, speed or altitude changes. It does say the log is playing but I am unable to see any of the planes functions.
I have been struggling with this for a week now and do not know what to try next. If anyone could give me some suggestions that would be greatly appreciated.
Ryan
Permalink Reply by Ryan on March 11, 2012 at 10:26pm HI,
Thanks for the reply. Your circling and flying away from you is exactly like I experienced in all but my last flight. Good to know that you were able to find a fix. The crash I experienced today was not a big deal I just hope to learn something from it.
The thing that messed me up the most was the logs. I am convinced now that there was something wrong. Earlier I figured I was doing something wrong when trying to read the data logs and nothing was working.
So to summarize I did learn to ensure that the data logging is working and to check the data. If things are not working correctly I will send it back to be checked out.
Funny thing is how do the gears in the aileron servos get stripped out in the crash. The plane hit about level directly into the nose. No damage to the wing at all besides striped aileron servo gears. Hitec 65HB servos. The tail boom of the plane cracked right in half and the stabilizer was hooked under the nose on the wire landing gear. Didn't have my phone on me and it was muddy where it crashed other wise I would have some pictures.
You are correct working it out is lots of fun. Glad your FPV missions have went well. Have any pictures of your plane?
Permalink Reply by Damian ONeill on March 12, 2012 at 12:50am Here you go.
Cheap and with PIDs already available.
I don't know much about electrics as I have only really sloped and mainly DS. But this was easy with a few mods on the spar. The last photo is my new one ($34) which I am putting esc and OSD in the fuz to save room and get the cog back without too much weight on the tail. (HK Raptor probably better and a bit more room but sold out).
Permalink Reply by Damian ONeill on March 12, 2012 at 1:30am Hers the other 2 pics
Permalink Reply by Ryan on March 12, 2012 at 7:55pm Thanks for the pictures. I think my next plane to fly the APM will be that exact one.
Permalink Reply by Ramesh Tahlan on March 27, 2012 at 10:34pm i have pasted this below from the Appendix section on lights of DIY on the colour of ABC lights on APM2, but in the colour pics on that page the colour of A on APM1 is Green and in APM2 is Red, so i hope, that what is written for A and C in text is correct....
| LEDs: | Behavior: |
| Power | On when powered |
| TX | Shows data coming in USB/FTDI port |
| RX | Shows data going out on USB/FTDI port |
| A C | Fast flashing while calibrating gyros, then pause, then rotation flashing (about 45 seconds total). |
| A | Flashing = Code loaded or loading, ready to arm. Solid on = Armed, ready to fly (arm by holding rudder stick full right for 4 secs) |
| C | GPS lock - C Flashing while waiting for GPS lock; Solid with GPS lock. |
| A C | Solid A and C and you are ready to fly |
Permalink Reply by Thorsten on March 30, 2012 at 12:25pm Hi,
I found the information about LED description here at the topic.
Because I like to check my APM2 about a fault. At the description I found out that LED A B not flashing.
My freind have the same APM2 and it is still working.
If it possible at any case over terminal or Mission Planner to activate the LED for testing?
Maybe you can replay with PM to send me a link where I can found more information.
Also I have some points which are not logical from me. Drift and shift left some times with no imput from the RC.
Maybe the Gyro sensor have some defect or working not fine :( At the moment I didn'T know what I should can do to found the root cause to fix it.
Thanks.
Thorsten
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1277 members
24 members
183 members
246 members
179 members
Powered by
