Is there any difference in board dimensions?
Will they both fit the same mounting holes?
Will they both fit the same plastic case or is there a new case on the way for the APM2.5?
Tags:
Permalink Reply by Eyeindasky on August 7, 2012 at 5:14pm
There is a new case, but I understand that the dimensions are the same. Just some ports got moved and the holes don't line up.
Jason
Yes, Jason's right. Same mounting holes and overall board XY dimensions, but some ports have been moved around. It's possible to use the old enclosures and cut/enlarge some holes, but better to use the new enclosures.
Permalink Reply by David Settles on August 13, 2012 at 8:57am From reading on one of the other ( and many) forums when you buy the 2.5 it comes with a case. I hope so because I did not order one and I would have.
Right now, when you order APM 2.5 you get a credit for a free case when they become available (in about a month).
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.125 members
39 members
4 members
24 members
1286 members
Powered by
