Jason is travelling this week, so I'll take the helm for the next software release post.
UPDATE: the motor remapping thing was confusing everyone, so we took that out and returned to the regular motor mapping. That means that APM 2 users with Hexas and Octos should wait for the next version. APM 1 users should be fine with any frame.
NOTE: Hexa and Octo users: there have been motor mapping changes that may affect you. Please don't upgrade until we can update the documentation to reflect the changes. This should happen by the end of the day today (Feb 1).
ArduCopter 2.3 is now available in the Mission Planner. This is the next revision of the ArduCopter 2.2B6 code, which is perhaps the most tested code we've ever released (1288 comments in the thread!) and certainly in my experience the best code, too.
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P (default is 0.14, so start by turning it down to 0.1. In general tune PIDs in 25% steps).
Now that we've got solid code out there, we can turn to collecting suggested gains for standard frames, and a better guide to how to tune PIDs for your unique setups.
Here are Jason's note on the latest changes (mostly from 2.2B6)
A dampening term called STAB_D has been refined. A D term for all of the Rate based control loops has been added based on Igor's work. Landing for Baro and Sonar has been refined based on JLN's work. A slightly new approach to Loiter and Navigation is being used to try and linearize the pitch and roll for rate control. It tends to use lower gains, yet has a more assertive response in the air.
STAB_D : This is the gyro accretion dampener. This can remove small wobbles during sharp changes in angle commands. Making this too high can have a negative effect in performance and add a memory effect that can cause temporary loss in control. The in flight tuning is ranged so you are just below that effect.
If you haven't noticed before the control loops are in two stages. The first is a PI stage that converts some sort of position or angle error into a desired rate. These generally do not need to be tuned. They are more of a user preference on how fast you want the copter to perform a motion.
The second stage is the actual PID loop that needs to be tuned for the copter. This converts the desired rate into a motor command of some sort. I added a D term based on Igor's recommendation to the PI's for each rate controller. These should show up soon in the mission planner for the release. I cannot give you a concrete answer for how to tune the D terms, because they each depend on their function such as alt hold or loiter, etc.
Still, the absolute most important term is always the Rate_P term for each loop. Start tuning here.
The default PIDs are in the what flies great for a stock jDrones/3DR Quad with the purple motors in X mode.
Note the Mission Planner does not yet highlight these D terms on the main tuning page (it will soon), but you can find them and modify them on in the Parameters list.
Autolanding should now work well (see video above) and the Tri servo issue is now resolved.
The code should now compile with Arduino 1.0 (thank, Randy!), but remember that you need to use the "relaxpatch" version of Arduino in our downloads section.
[Update: we've reverted the below. See update at the top of the post]
Important for Octo users:
We've changed some of the motor orders for some more exotic airframes. We'll be updating the docs on the Wiki in a day or two to reflect this. Pat Hickey explains:
As before, the hexa plus APM2 motor setup has changed from the ordering [1, 2, 3, 4, 5, 6] to [ 5, 6, 1, 2, 3, 4 ].
The Octa V layout for APM2 is:6 42 58 13 7Motors 1 through 4 spin clockwise, and 5 through 8 spin counterclockwise.
Tags:
There is only one direction the sound occurs at.
Check out the mechanical, bearings, prop crack, etc..
Permalink Reply by Fatih Gokce on February 12, 2012 at 5:14pm Hi,
We flied with 2.3 firmware using jdrones default quad arducopter to try auto landing.
In one of our trials we adjusted our three modes as 1-Stabilize, 2-Loiter and 3-Land. When we switched from stabilize to loiter and then immediately after loiter to land, the copter switched to RTL instead of land.
In a second trial our modes was 1-Stabilize, 2-Stabilize and 3-Land. In this case we switched to land after a manual take off and stabilizing the copter. But again the copter switched to RTL.
Is this normal?
That doesn't sound normal to me. If you switch to land straight from stabilise or loiter it should land at it's current position instead of trying to return home. I've checked this by looking at the do_land command in particular this line which should cause it to land at it's current position:
// hold at our current location
set_next_WP(¤t_loc);
Could you check your log files and ensure the MOD:LAND line appears intead of MOD:RTL? Maybe stick your logs here or create an issue on the issues list.
Permalink Reply by Fatih Gokce on February 13, 2012 at 7:04am Thanks Randy,
We solved/understand the problem.
We inspect the code and realised that, as a failsafe, if battery monitor is enabled and a low battery event occurs the copter enters in RTL mode, if the mode is equal to or greater than AUTO (events.pde, lines 55,56). In our case we set our low battery threshold at 10.2 V and preferred to fly at lower voltages without being unaware of this failsafe. And the copter entered to RTL.
In most cases this failsafe is logical. But for landing there is something different: If user gives an immediate landing command, returning to home can consume much power. I will add this as an issue.
As a suggestion a warning message can be added in battery monitor section of GCS.
Permalink Reply by Tomas Soedergren on February 14, 2012 at 9:55am Good catch, Fatih!
I think this serves as another example illustrating the importance of functional documentation (wiki´s), how thoroughly and complete they are written and updated (prioritized).
If a voltage drop can trigger RTL, then this must be explained in all relevant sections (failsafe, RTL, voltage / discharge monitoring wiki´s).
The disturbing fact is: Information that exists in a too much fragmented way (in old forum posts or semi outdated wiki´s) is virtually as useful as no information.
Permalink Reply by Dustin on February 12, 2012 at 10:12pm I've tried to ask this a couple times and don't seem to get a straight answer. Is there anything Hex+ people can do to get up and running on APM2.0? ie. Is there documentation that matches the current code? I can see in the code comments that the motor changes were taken out... but, information seems to be disseminated in various forums and it's hard to get a solid status on things. The 'update' in this thread indicates hexes and octos need to wait until the next version. What exactly does this mean? Is there a motor configuration we can go with now to get in the air?
Thank you.
Dave: Hexas work now. It's just that we may change the motor order for APM 2, so you might have to switch some cables around. Documentation is waiting for that.
Permalink Reply by Vincent Mees on February 13, 2012 at 11:31am Pfff,
I'm still having twitches with 2.3, even with rate D at 0.
To check there is nothing wrong with HW I reloaded v49 and it flies good.
Is someone using MT2814 with turnigy plush 25A ESC's??? Just to compare??
Also changed TX and RX.
I saw Jason mention creating a tuning video on one of the dev. lists a few days ago. Maybe this will be the answer to many of these tuning type issues- a process that is guaranteed to work with our structure.
Permalink Reply by Ihab Ali on February 13, 2012 at 12:51pm Did you try lowering your Stab_D term? on my setup(using the same ESCs but KDA motors) I found that after tuning down Rate_P(with the default Rate_D set to zero) to eliminate oscilations I had to lower the Stab_D term a bit to get rid of the twitches.
Permalink Reply by Vincent Mees on February 13, 2012 at 1:08pm Ihab,
I will try, thx
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
51 members
11 members
182 members
1290 members
Powered by
