Jason is travelling this week, so I'll take the helm for the next software release post.
UPDATE: the motor remapping thing was confusing everyone, so we took that out and returned to the regular motor mapping. That means that APM 2 users with Hexas and Octos should wait for the next version. APM 1 users should be fine with any frame.
NOTE: Hexa and Octo users: there have been motor mapping changes that may affect you. Please don't upgrade until we can update the documentation to reflect the changes. This should happen by the end of the day today (Feb 1).
ArduCopter 2.3 is now available in the Mission Planner.  This is the next revision of the ArduCopter 2.2B6 code, which is perhaps the most tested code we've ever released (1288 comments in the thread!)  and certainly in my experience the best code, too.
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P (default is 0.14, so start by turning it down to 0.1. In general tune PIDs in 25% steps).
Now that we've got solid code out there, we can turn to collecting suggested gains for standard frames, and a better guide to how to tune PIDs for your unique setups.
Here are Jason's note on the latest changes (mostly from 2.2B6)
A dampening term called STAB_D has been refined. A D term for all of the Rate based control loops has been added based on Igor's work. Landing for Baro and Sonar has been refined based on JLN's work. A slightly new approach to Loiter and Navigation is being used to try and linearize the pitch and roll for rate control. It tends to use lower gains, yet has a more assertive response in the air.
STAB_D : This is the gyro accretion dampener. This can remove small wobbles during sharp changes in angle commands. Making this too high can have a negative effect in performance and add a memory effect that can cause temporary loss in control. The in flight tuning is ranged so you are just below that effect.
If you haven't noticed before the control loops are in two stages. The first is a PI stage that converts some sort of position or angle error into a desired rate. These generally do not need to be tuned. They are more of a user preference on how fast you want the copter to perform a motion.
The second stage is the actual PID loop that needs to be tuned for the copter. This converts the desired rate into a motor command of some sort. I added a D term based on Igor's recommendation to the PI's for each rate controller. These should show up soon in the mission planner for the release. I cannot give you a concrete answer for how to tune the D terms, because they each depend on their function such as alt hold or loiter, etc.
Still, the absolute most important term is always the Rate_P term for each loop. Start tuning here.
The default PIDs are in the what flies great for a stock jDrones/3DR Quad with the purple motors in X mode.
Note the Mission Planner does not yet highlight these D terms on the main tuning page (it will soon), but you can find them and modify them on in the Parameters list.
Autolanding should now work well (see video above) and the Tri servo issue is now resolved.
The code should now compile with Arduino 1.0 (thank, Randy!), but remember that you need to use the "relaxpatch" version of Arduino in our downloads section
[Update: we've reverted the below. See update at the top of the post]
Important for Octo users:
We've changed some of the motor orders for some more exotic airframes. We'll be updating the docs on the Wiki in a day or two to reflect this. Pat Hickey explains:
As before, the hexa plus APM2 motor setup has changed from the ordering [1, 2, 3, 4, 5, 6] to [ 5, 6, 1, 2, 3, 4 ].
The Octa V layout for APM2 is:
6            4
  2        5
    8    1
      3 7
Motors 1 through 4 spin clockwise, and 5 through 8 spin counterclockwise.
Support for roll/tilt camera control on APM 2 should be coming in the next version. Traditional Heli will also be updating to this latest code as well once we track down a memory issue.
As always, you can see a complete list of changes in the changelogs.
Yep keep them all charged up mine are come on guys were is 2.4 ? :-)
im preparing GIT on my computer :p
peep peeeep, oh no, battery charged :D
I've put ArduCopter 2.4 in the downloads section. There may be a few more little tweaks before we push it out to the hex for everyone, but it's flying very well and ready for beta testing by more than just the dev team.
Just downloaded and tried to upload to APM2 via relaxpatch arduino.  I get this error (haven't seen this before):
redefinitions of 'void init_motors_out()'
ArduCopter.cpp: In function 'void init_motors_out()':
motors_quad:33: error: redefinition of 'void init_motors_out()'
Heli_H1:39: error: 'void init_motors_out()' previously defined here
ArduCopter.cpp: In function 'void output_motors_armed()':
motors_quad:48: error: redefinition of 'void output_motors_armed()'
Heli_H1:53: error: 'void output_motors_armed()' previously defined here
ArduCopter.cpp: In function 'void output_motors_disarmed()':
motors_quad:155: error: redefinition of 'void output_motors_disarmed()'
Log:5: error: 'void output_motors_disarmed()' previously defined here
ArduCopter.cpp: In function 'void output_motor_test()':
motors_quad:186: error: redefinition of 'void output_motor_test()'
Log:23: error: 'void output_motor_test()' previously defined here
I pulled the library and the arducopter folders
It compiles fine for me on Arduino 022 relaxpatch
Worked fine for me on Arduino 1.0 relax patch too
Chris - I look forward to trying it out, not before Monday unfortunately. Will there be an update somewhere on what the changes are? Any changes to tuning strategies? Regards, Bill
Yes, when we post it to the MP we'll announce all changes. The main difference in tuning is that stabalize and acro and nav have different gains, so you can fly "soft" in stabilize (very stable) and still have tight navigation/loiter performance.
Ive been away all week so just catching up before heading off again tomorrow to Middle East. Is 2.3.1 out yet?  Also is there anyway to look at params on the MP without the APM connected ? This would be useful while sitting on a plane to play with on long trips (instead of boring work of course)
Just pulled the GIT version and loaded 2.4
Only to do some handtests and see if the twitches are gone.
I don't no if its my setup or the SW but my quad wants to random fly in different directions. No oscillations.
Using default PID and those that Marco provided.
Is the GIT version fyable??
Yes, I have just ended a test flight and it was supperb, I used Marco's PIDs and just tuned RATE R and P to 135 and it's flying marvelous without touching anything else, and no twitches whatsoever. I believe this params to be more tolerant. Nice job (attention this is not the final release, it may have some bugs to clear out, fly it by your own risk).
