Version 2.4 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area. Although not as big a change as the 2.3 release, it still includes a respectable number of enhancements and bug fixes.
Enhancements:
Bug fixes:
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
Thanks go to the numerous contributors including users and their detailed bug reports, developers and testers. Hopefully all together this will add up to a nice smooth release!
As per usual, please post your comments, issues in this discussion. For enhancement requests for future versions, feel free to add them to the issues list. Note: you can "star" an issue to receive emails when someone comments on the item. On the dev side it helps us because we can get an idea as to which feature requests are the most popular by sorting by the number of people how have starred each issue.
Tags: ACM, Heli, Quad, Traditional
You're flying the APM2? You probably already know but generally consensus is that the slow accumulating lean is due to vibration.
Ah, yes, see my numerous previous posts, graphs and logs on this thread. I have vibe-insulated the c**p out of the quad/motors/props/board, tried 7 different types and densities of foam and rubber to try insulate the board, magnetically balanced the props, mounted the motors on rubber pads, etc. Spent two days trying to sort it out. Have only had sudden death lean and slow accumulating lean with APM2.
I have now shelved APM2 and put APM1 back on my quad. Based on my difficulties trying to reduce vibrations for APM2 I predict there's going to be lots of unhappy people when they install their boards. Hopefully I'm wrong!
Permalink Reply by Jonathan M on February 24, 2012 at 9:57am I think that Chris mentioned v2.5 attempting to use some S/W filters for the APM2. Fingers crossed.
I have had the "leans" with my APM2 setup from the very beginning. My larger motors are difficult to balance as i have them currently. It's improved recently with v2.4 and better APM isolation on my part, but it's still present. I can fly the quad much easier now, but I don't believe it's ready for FPV or aerial photography yet.
Permalink Reply by Dave C on February 24, 2012 at 3:45pm Do you do fpv already? If not, get the '$100 quad' with the cheapest camera you can find, kk controller and go for it, you will crash, better on that than the ardu. But you'll be having amazing fun, I'm loving it, been doing tree runs and everything :) Then when the day comes to stick it on the ardu, firstly the ardu is intact and ready to go, but secondly you've got bit of understanding of whats going on but now with all the capabilities of the ardu, FPV autoway point (despite my awful tuning) is an almost pant wetting experience :)
And I'm one of those 'extreme sports' kind of dudes....
My FPV flights from Arducopter, V2.3! >Here
While not strictly FPV in that video I did two batteries on the next two flights with FPV goggles. Love it!
Graham, did you ever try putting a metal plate between your APM and the frame?
APM/pad/plate/pad/frame ???
Was last: APM2/softerfoam/softfoam/thinply/hardfoam/frame
The thinply isn't good enough. It's too light. And with the hardfoam, it's probably not doing anything for you. Try a plate of aluminum.
I don't KNOW this will work, just an idea to try.
To tell the truth I have given up on APM2 for the time being, the amount of time & effort required to try insulate this thing against vibrations for me is just not worth it, I was getting no-where. The correct insulation window must be so small and with the hardware variations out there, wow. I'll come back to it in a few weeks when it's matured a little.
I have put APM1 back on the quad (on the same mounts), did some tuning and had 4 very good flights this afternoon, off to do some FPV tomorrow.
How does that work? I think I have an idea, and if right, it's pretty slick.
51 members
133 members
1298 members
249 members
Powered by
