Version 2.4 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area. Although not as big a change as the 2.3 release, it still includes a respectable number of enhancements and bug fixes.
Enhancements:
Bug fixes:
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
Thanks go to the numerous contributors including users and their detailed bug reports, developers and testers. Hopefully all together this will add up to a nice smooth release!
As per usual, please post your comments, issues in this discussion. For enhancement requests for future versions, feel free to add them to the issues list. Note: you can "star" an issue to receive emails when someone comments on the item. On the dev side it helps us because we can get an idea as to which feature requests are the most popular by sorting by the number of people how have starred each issue.
Tags: ACM, Heli, Quad, Traditional
Permalink Reply by Jason Wise on March 10, 2012 at 7:40pm Hi Rui, Im powered via a uBEC, attached is my log, my flip occurs about 72% through playback, about a minute or less prior its twitching on the pitch axis...although Im not 100% knowing what Im looking at via the log file
Thankyou in advance
Gotta ask; Motor connections soldered or bullets?
Permalink Reply by Jason Wise on March 10, 2012 at 10:13pm Bullets, never had a flip issue prior
Permalink Reply by Balloon on March 11, 2012 at 2:04am Hi, Marco
I'm find problem about Altitude level. when i will take off my arducopter and connect APM Planner. It have show altitude in negative (-) or under zero. (first connect battery is show altitude zero. and i will alt_hold or loiter about 10 meters but altitude is little up to on the air and HUD in APM Planner is show -10 - 2 meter. I thinking is a bug about altitude barometer?
and have my logs Barometer measurement error.
thank you,
Balloon
Hi Ballon, now there's another alt_hold management, i think better... try with the latest GIT, but i've compass issue with this one... :-(
I leave here the parameters of my little quad, in my opinion are a good starting point, especially for the sections STAB / RATE / LOITER, with default parameters have never been able to get a good loiter, but with these yes, my videos speak for themselves.
Marco
Marco, tried to fly today with the last git version you sent me (GIT_RM_120309)
I was mortified to see the "leans" problem back again and yaw drift (which I've never, ever had before). Log attached.
I thought these had been fixed?
Haven't flown the newest version you've posted yet.
Try again with my latest version here.
OK, tried the latest version and it seems fine, but I've lost my trust again a bit so will have to do some more flights to make sure.
Just had a few flights again, yaw is not right - it doesn't stay correctly pointed, it wonders in the hover and in forward flight. Not nice at all
I know dear Graham, I've already reported on the dev list for a long time and at the first fly with this release, nothing new for now, the problem persists... :-(
Permalink Reply by Tomas Soedergren on March 10, 2012 at 6:40am HI guys,
This morning (Scandinavian time) I downloaded the 2.4.1 from GIT and gave it a try on my quad (3DR stock, APM2).
I did not like it. Acting up in yaw, not as solid in stabilize, and a bit jerky in altitude hold.
I submit the log here, in case it might be of any interest.
I shall admit that I did not make any real effort to tweak parameters (I had a doubt it would help).
Now I revert to the 2.4.1 I pullet of git 28 feb. I cant say it is solid but for me it is at least better.
/ Tomas
Ps. baro sensor only, except last minutes. As you can see then, my sonar setup sucks.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.185 members
51 members
24 members
1295 members
687 members
Powered by
