Version 2.5 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area!
Enhancements:
Tuning:
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
While some testers have reported very good flights with the default PIDs, some have reported that this release is a little "sharper" due to the DCM improvements and have found they needed to:
reduce stabilize P by 10% (i.e. 4.5 -> 4.2)
reduce stabilize D by 30% (i.e. 0.15 -> 0.10)
increase rate D from 0 to 0.001
Tuning loiter can be tricky. Refer to the discussions which will appear below for more community feedback on what parameters work best.
Please post your feedback in this discussion. For enhancement requests and bug report, please add them to the arducopter issues list. When possible please include logs (tlog and/or dataflash) and tell us whether you're using APM1 or APM2 and what version of the software you're using (presumably 2.5 but tell us anyway!).
Thanks for this release go to the developers (both in the core team but also those who have provided bug fixes through the issues list) and also the community members who participated in the previous release thread and provided some great detailed information in the form of issue reports and logs which allowed us to nail some bugs!
Permalink Reply by Dave C on March 22, 2012 at 1:05am So.....
How much fun can you have with an arducopter?
Well here’s a start :D
Oh and it’s a lot better to watch in 720p, and turn it up loud!
As always, I will buy a better camera soon ;)
Arductoper 2.5. Rocking. from Kamakaze UK on Vimeo.
APM1, 3DR Frame, Standard Jdrones 850KV kit. 10*4.5 cheap plastic props. NO vibration mounting whatsoever, AMP just foam tape glued to frame, this is significant ;)
There is, of course, an ‘out-takes’ video ;)
Permalink Reply by Dani Saez on March 22, 2012 at 1:20am WOW Dave, really cool video!! you sure had fun in this one!
I bend myself on your second FPV take off between those branches, thought I'd hit them :D hahahaha
Congrats man!
Can't wait for the out-takes!! ;-)
ps: I like your taste!!, You got the same color leds I have on my small Quad, you know, being from Barcelona.... ;-)
Permalink Reply by Jan Schermer on March 22, 2012 at 4:35am :D this is cool
Permalink Reply by Jason Wise on March 22, 2012 at 3:20am Im having similar issues to others with my hexa, my yaw is surging while attempting to hover
Permalink Reply by TonyP on March 22, 2012 at 5:22am Hi Folks, new to the forum and ArduCopters (since December this year) and been having heaps of fun and crashes LOL. I like this release, however have come across a strange issue, which may be a bug.
If I go to terminal mode and run setup and then motors, I expect the motors to spin briefly in a clockwise direction from motor 1 in turn, however I get something different.
This is the sequence I get
M1 spins ok, stops
M2 spins, then slows slightly
M3 spins, then stops (M2 still spinning)
M4 does not spin at all, and then M2 stops.
Sequence repeats
This worked fine under 2.4.1, and I rolled back to 2.3 last night, and the motors test worked ok (if you recal you need the remote to spin up pais of motors).
My setup is the 3DR frame, APM1, 850Kv motors.
Tony
Tony, we're updating that test in 2.5.1. You can try a beta (if you're willing to load with Arduino) here.
Permalink Reply by Jonathan M on March 22, 2012 at 8:06am Chris, any explanation as to what has been changed for 2.5.1 vs. 2.5? 2.5 seems to be flying great for me currently, but if there is a hidden bug, I definitely want to change the firmware. Thanks
There's a list here if it helps: http://code.google.com/p/ardupilot-mega/source/list
You can see all updates in the changelogs here. No serious bugs, but little things that we've fixed or improved. We'll release 2.5.1 in a day or two, when testing is complete.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.43 members
24 members
8 members
51 members
184 members
Powered by
