Version 2.5 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area!
Enhancements:
Tuning:
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
While some testers have reported very good flights with the default PIDs, some have reported that this release is a little "sharper" due to the DCM improvements and have found they needed to:
reduce stabilize P by 10% (i.e. 4.5 -> 4.2)
reduce stabilize D by 30% (i.e. 0.15 -> 0.10)
increase rate D from 0 to 0.001
Tuning loiter can be tricky. Refer to the discussions which will appear below for more community feedback on what parameters work best.
Please post your feedback in this discussion. For enhancement requests and bug report, please add them to the arducopter issues list. When possible please include logs (tlog and/or dataflash) and tell us whether you're using APM1 or APM2 and what version of the software you're using (presumably 2.5 but tell us anyway!).
Thanks for this release go to the developers (both in the core team but also those who have provided bug fixes through the issues list) and also the community members who participated in the previous release thread and provided some great detailed information in the form of issue reports and logs which allowed us to nail some bugs!
John, mechanically cutting power would be difficult. Much much easier to use a MOSFET to disconnect the battery. You could use a MOSFET driven from a receiver controlled switch, plugged into a spare channel on the APM.
Or use an Arduino Nano to watch a 1second heartbeat signal from the APM. If the signal stops pulsing, it could automatically kill power.
Permalink Reply by John Campen on April 21, 2012 at 5:38pm that sounds the way to go. So any advice how to make this? Id still like to be able to use channel 8 though. It always bugs me we have a spare channel we cant use.
Ok, so for Ch8 control, use something like this:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
To drive a FET, rated at however many amps you need:
http://www.digikey.ca/product-search/en/discrete-semiconductor-prod...
Hello Robert! I'm french and i've seen that you've make an upgrade in APM for the H4 swachplate (four servos) to mount APM on a Vario Benzin Trainer.
How to include it in the standard TradHeli V2.5.4 software for APM1, please?
Have a nice day!
Jean-Marie
Permalink Reply by John Campen on April 23, 2012 at 4:09pm wow ready made , that's the way to go!. Now to just get the channel 8 liberated!
Permalink Reply by John Campen on April 23, 2012 at 4:40pm wow, the ready made one looks the way to go. But is 10amp going to be ok? Now we just need to get the channel 8 liberated!
Permalink Reply by James on April 21, 2012 at 6:06pm i have thought about this quite a bit, and while im all for working on a full failsafe i think we could apply a pretty good safety measure with little complication.
i think that in any flight mode zero throttle should mean zero throttle. its the simplest, quickest stick input we can give in an emergency.
i know its a long way from a separate system running outside the main code but it could minimize the damage in a lot of situations.
james
Permalink Reply by John Campen on April 21, 2012 at 6:47pm or can it be done in a way that absolute zero throttle in flight modes can be activated using a switch?
Permalink Reply by James on April 22, 2012 at 5:13am i dont see the need, im assuimg that radio is connected and the main loop is running. in this situation we already have a channel dedicated to throttle and its just a change in the motor control logic.
i feel this could also dramatically improve autoland, cutting the throttle the moment the quad touches the ground would eliminate all that bouncing and skating around.
james
Permalink Reply by John Campen on April 21, 2012 at 7:39pm this is what I want on my copters http://www.youtube.com/watch?v=7dDxGKxNsfw
me too,but for my big hexa +3kg that should be very big parashute...
Permalink Reply by Glenn M on April 22, 2012 at 9:01pm Does the new copter_leds code in 2.5.4 work using the same pins as u4eake's showleds code? (AN8-15)? Should it be connected the same way?
Mine didn't seem to work with a fresh 2.5.4 firmware from MP, but it does work if I disable copter_leds and go back to using show_leds with firmware uploaded via arduino.
51 members
184 members
51 members
8 members
Powered by
