Version 2.5 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area!
Enhancements:
Tuning:
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
While some testers have reported very good flights with the default PIDs, some have reported that this release is a little "sharper" due to the DCM improvements and have found they needed to:
reduce stabilize P by 10% (i.e. 4.5 -> 4.2)
reduce stabilize D by 30% (i.e. 0.15 -> 0.10)
increase rate D from 0 to 0.001
Tuning loiter can be tricky. Refer to the discussions which will appear below for more community feedback on what parameters work best.
Please post your feedback in this discussion. For enhancement requests and bug report, please add them to the arducopter issues list. When possible please include logs (tlog and/or dataflash) and tell us whether you're using APM1 or APM2 and what version of the software you're using (presumably 2.5 but tell us anyway!).
Thanks for this release go to the developers (both in the core team but also those who have provided bug fixes through the issues list) and also the community members who participated in the previous release thread and provided some great detailed information in the form of issue reports and logs which allowed us to nail some bugs!
Greg: there's nothing wrong with the MTK -- we fly with it every day. Sure, our forthcoming Ublox GPS is better, and like all other technology we upgrade our product line every six months or so, but thousands of people are flying sucessfully with the MTK today.
Here's some logs from my flights yesterday with the MTK in 15MPH gusting wind
Loiter (green
Two waypoint missions:
Inspiring!
Have you ever described your equipment in detail? Close-up pictures, cable arrangements...
Lars
As Chris has also written with MTK can get good results, but far enough away from the performance of U-Blox.
This evening (local time) I put here a mission done with my quad, Google Earth shows very straight lines in the movement, with very little angle or curves, while in the images of Chris is clearly seen that wave at the center of each leg.
With U-Blox does not happen.
Hello Marco and thanks for fascinating videos!
Where did you put the mission? I haven´t seen it here around.
Lars
Edit within 15 min:
Sorry, I have found them. Congratulations and continue to show reports about your flights.
Lars
Looking at the difference I can see the improvement with Ublox, Is Chris using the same firmware? I think a true test would be using the same craft same firmware and same pids and only change the gps units and see the difference?
I have my Auto mode working fairl well but cant change gps units easily as I have the apm2.0 with daughterboard. And I cant test this myself as the gps data I get from the flashlog is incorrect and will be until the code is changed. See here link to discussion. Looking visually the results I get with no wind are good but this needs to be tested by me with the gps overlay.
Tomorrow i swap the gps unit and i try two identical AUTO mission...
Permalink Reply by Greg on May 30, 2012 at 2:47am Hi! Marco,
I like your videos, they are very demonstratives!
I can't wait to try the V2.6 code on my Hexa!
Thanks very much for your good work.
Guy
Permalink Reply by Mike Mac on May 29, 2012 at 6:27am Will the new U-Blox GPS become a standard part of the AMP2 in the future or will that be an add-on GPS? I’m just trying to figure out the upgrade path for us current AMP2 owners that have built-in GPS?
Permalink Reply by Chris Whiteford on May 29, 2012 at 7:27am I was fortunate enough that I had seen that this new GPS was coming and was able to cancel my original order with the integrated GPS unit and re-order the APM2 without it.
But I suspect that the upgrade path will be having to get the other daughter board without the GPS. Though those aren't for sale separately yet.
It would be great if we could get some more info on this new GPS though. Even a post that says "Hey wait on ordering GPS units... we have a new one coming"
chris.
Permalink Reply by Vincent Mees on May 29, 2012 at 8:45am Is there news on the price tag of this new GPS?
Permalink Reply by Jeff Milay on May 29, 2012 at 11:17am Marco, your videos are inspiring! I can't wait to get mine tuned as well as yours! (If ever! Haha!) I posted a video earlier in which I was battling a 15mph constant wind with 25mph gusts. Any suggestions on tuning loiter to help battle the winds? Need to adjust Hld_Lon_I and Hld_Lat_I I'm assuming? The conditions were not good for testing but I couldn't resist flying! Thanks again for any suggestions and thanks for awe inspiring videos!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
1299 members
24 members
48 members
51 members
Powered by
