ArduCopter 2.7.1 will become available on Mission Planner and in the downloads area shortly. This release contains a few important bug fixes as well as the first implementation of the MPU6000 sensor-fusion code.
Detailed changes are in the commit log. Here's a summary:
New:
- Preliminary support for MPU6000 on board sensor-fusion (DMP)
- AP_Limits: Experimental "bounce" mode, for smaller spaces (LIM_RECMODE)
Bugs:
- Bug fix for yaw error buildup on takeoff
- Fix in Auto mode for failsafe handling
- Fixes to 3-axis camera gimbal code
Tags:
Thanks, Andreas! It's in the Mission Planner now.
Permalink Reply by Kevin Brown on August 1, 2012 at 7:32am Very Cool I will try to test this afternoon
Permalink Reply by Don Fiedler on August 1, 2012 at 7:41am Does this address the wobble in loiter mode...........Don
Permalink Reply by Eddie Weeks on August 1, 2012 at 11:17am yeah... My tri on 2.7 would Loiter great.. just a obvious wobble.. what caused that ?
Permalink Reply by Stephen Gienow on August 1, 2012 at 12:35pm How do I implement crosstrack, is it CLI only? It is grayed out on the config screen.
Permalink Reply by Stephen Gienow on August 1, 2012 at 1:19pm On the Arducopter Config screen it says Crosstrack Correction but it is grayed out at 0. On Parameter list it says XTRK_GAIN_SC, and I can chnage that. Should I change that value for crosstracking?
Permalink Reply by Matt Gaige on August 1, 2012 at 12:42pm So what is meant by "sensor-fusion"?
The MPU internally "fuses" the Gyros and Accels to calculate orientation. Currently this is done in the Atmega 2560. If the DMP can do it well, it will free up a lot of overhead in the Atmega.
Permalink Reply by Matt Gaige on August 1, 2012 at 1:03pm Thanks, this is understandable. So does "Preliminary" mean it is only partly implimented at this time?
Matt, it has flown at least once and is intended for A/B testing (comparison) by experienced pilots. The code is brand new, so caution is required.
Permalink Reply by Alex on August 1, 2012 at 1:16pm APM1. Camera gimbal is not working. The Pitch and Roll axes not correctly work.
Permalink Reply by Paul Williams on August 1, 2012 at 9:03pm Go to the config list then make sure the Yaw is set to 0
then it will work correctly.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.684 members
4 members
1291 members
110 members
184 members
Powered by
