Hello,
I have ordered an arducopter ESC 20A and a motor (850kv, A-2830/12) because I want to understand how it works and how to interface it to an arduino. In addition to these components, I have a battery 3.7V 2000mAh. I am pretty new to this things and need some basic help.
When I connect the motor to the ESC and the ESC power to the battery, with the white little cable to the arduino and the black little cable to the ground, the motor makes a sound that I identify as "123 tone". And it keeps doing it, again and again. And the motor doesn't rotate.
Why is the motor making music and not the ESC ? is it normal ?
I can't find any documentation on this particular case where the 123 goes on and on. Do you know what it could be ?
I am wondering if simply the battery is not fit for the purpose. What do you think ?
I thought it might be the battery, thus I tried to power the ESC with the arduino. First I put the positive power cable of the ESC in the 3.3V of the arduino and the ground to the ground but nothing happened. No sound, nothing.
Desperate :), I tried to plug the power in the 5V and I got the sound indicateing a bad voltage (beeping every second).
How should I do to power the esc with the arduino ? is it possible at all ?
Thank you very much in advance for your help,
Best regards,
Barth
Permalink Reply by Barth on May 1, 2012 at 8:56am Ok, I think that I can confirm that my battery is incorrect. I should use a higher voltage, a LiPo 3 cells or something similar.
Cheers
Permalink Reply by Lloyd Breckenridge on May 1, 2012 at 2:40pm You need to treat the esc like a servo.
Look for the arduino code for the servo sample.
Power the ESC from the battery via the positive and negative heavy cables on the ESC.
The three heavy wires go from the esc direct to the three wires on the motor.
The servo cable needs to be attached to the arduino pins that are described in the servo sample.
The ESC will probably not initialiZe unless you have the equIvalent of a low throttle signal from the arduino.
So you need to play with the code and set then signal all the way low on startup or at least when the battery is plugged into the esc.
Then you could use a button on the arduino to vary the servo signal after the ESC has initialized.
Permalink Reply by Lloyd Breckenridge on May 1, 2012 at 2:41pm Oh and that battery probably does not have enough voltage.
Use a 12volt dc power supply instead of the battery for testing.
Permalink Reply by Barth on May 2, 2012 at 2:59am Hello,
First of all, thank you very much for your valuable explanations. It is clearer now.
I realized that the voltage was wrong indeed. I have ordered a new battery. For testing I could use something like the item presented in this link, correct ?
http://www.graupner.de/en/products/294a2a60-66ab-4547-b822-8ff610f3...
I would have to adapt it to the Deans connector I have got on my ESC though.
Kind regards,
Barth
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1298 members
51 members
87 members
106 members
47 members
Powered by
