hi to everybody,
first of all i am sorry about my bad english :)
i upload a video about my problem
http://www.youtube.com/watch?v=IDkXjs10SkQ&feature=youtu.be
i have a problem , i have a apm2 board and i am using mavlink 1.0
i connect a 3g usb modem to my apm serial via 57600 baud.
but my problem is: my connection is not very fast everytime
and my connection is declerate when i am trying to connect
i have this error (your serial connection isnt fast enough)
i dont wanna first connection for parameters
i need a fast connection without parameter setup
can anybody help me?
best regards.
Tags:
using usb, change the param SR3_PARAMS to a number less than 50, say 20. this should help the connect process
Permalink Reply by TUFAN OZBEK on July 25, 2012 at 10:25am thank you very much
i solve my problem i change my serial baud 57600 to 4800 now, its connecting well
Permalink Reply by TUFAN OZBEK on July 29, 2012 at 7:01am hi mr. Oborne
i am connecting well via 3g modem or ethernet cable sr3_baud is 4800
but unfortunely when i use 4800 baud via 3g or ethernet cable , i am disconnecting 2 minutes after connecting.. i dont know why :(
i am using mission planner very good with directly ethernet cable and use 115200 baud. but when i use 3g modem and set 115200 baud i cant connect ( your serial link isnt fast enough )
i try to change sr3_params but nothing changed about connecting
so,
i think i need to connect with 115200 baud
but apm planner is giving error,
i need to incrase error delay time and maybe i need to send parameters slowly with 115200 baud
sorry for my bad english again :) if you dont understand my english i can upload a video about my problem
best regards
Permalink Reply by TUFAN OZBEK on July 29, 2012 at 5:34pm i solve all of my problems with udp connection
udp is very fast and fluently
i can connect very well and very fast
thank you
Permalink Reply by Tommy Larsen on August 4, 2012 at 11:40am Hi
What 3g modem are you using?
Tommy
Permalink Reply by TUFAN OZBEK on August 4, 2012 at 6:44pm huawei e176g with crc9 external 7 dbi antenna
Permalink Reply by TUFAN OZBEK on August 4, 2012 at 6:47pm i am using 3 device on my aircraft
Apm2 board >> serial to tcp converter >> 3g Router >> Huawei 3g modem
if you want i can send you connection and buying information
hello to norway from turkei
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
1283 members
24 members
180 members
4 members
Powered by
