I did two successful test flights with RC_01.
It seems all is set correctly. Behavior is as expected (very sensible, but I like that).
Now the questions :
- one ESC does not work (broken ? It does not output any voltage on the motor side; BEC is good instead at 5V). I exchanged it with one laying around. It works, but I prefer to have all ESC the same type. Unfortunately the original is out of stock. Is the one showed on the pictures (Turnigy, probably the same) a recommended substitute ?
- during the flights I had some issues, with motors suddenly stopping (and copter diving :( ; fortunately I was expecting some issue and then flying very low, so no damage).
What is going wrong ?
I noticed that there is another ESC which does not work properly, sometime stopping to work (?!).
I already found a bad solder on a motor connector. I have then to check for them all, but in this case I would prefer to solder my connections myself from start, not having to check for bad solder joints ... or experiencing them during a flight ...
- is NG firmware already flyable, assuming it is a beta (alfa ?) revision ?
This is a starting point.
I have some other questions about stabilization etc, but I would like to check all that better, with flight experience, before asking.
Out of curiosity, 10 minutes of hovering are 2220mAh consumption from a 3300 3S lipo.
Best regards,
Ric
Tags: arducopter, flight, quadcopter, test
There seem to be some soldering issues with the motor connections...
Check them twice
NG is being tested by the dev team at the moment and it's reasonable to expect an official release in the next couple of weeks. As it's a work in progress, changes are going into it all the time so it gets broken from time to time.
10minutes of hovering is pretty good. I think 7~10minutes is the average.
The motors suddenly stopping certainly sounds like a hardware issue although I once had a similar issue in which my quad would fly for about 30 seconds and then drop out of the sky. It was because I had wired things up incorrectly (i.e. not according to the wiki pages - http://code.google.com/p/arducopter/wiki/Quad_Radio ). My mistake was that I had plugged the power from the Power Distribution Board into the two power pins on the back-right of the APM instead of plugging it into the right-angle-pins on the back of the board (i.e. should have been plugged into one of the Servo Output pins). The difference is that if you use the two pins on the back right of the APM, it goes through a 5V regulator which consumes some voltage and this resulted in the APM board not receiving the power it needed.
-Randy
Hi Randy,
thanks or answer :)
So motor stopping sounds like an APM feed problem. I already connected it to right angle pins from start, so this seems not be the problem. I could suspect a BEC then.
I have two BECs already wired (separately !), one in preview for videocamera using. Will try to switch between them and report.
Ric
I did another 12' two flights (RC_01). I was able to restore the faulty ESC (?), so now I'm using all the same. I tried to swap between two different BEC.
There are some glitches on motors. Those are randomly on three motors (what I was able to notice) : front left and right and rear left (rarely). Sometimes they are very short glitches (motor suddenly changes rev and copter oscillates quick), sometimes they are enough to ground the copter on one side. Swapping between the BECs did not change anything, I guess I can rule out then a BEC issue.
It seems a brownout on ESC, but why randomly on different motors ? This suspect could be confirmed by the fact that (only) once an ESC reboot.
Or cold it be an IMU issue ?
Do make sense to test it with NG firmware ?
Thanks for help,
Ric
if you think it is because the voltage breaks down, solder a capacitor (or two) onto the power destribution board
Riccardo,
I had the same problem with my quad and found that the connectors between the ESC and the motors was causing the problem. I put the Quad on the ground and added just a little power and then wiggled the connections and found the motor's would cut in and out. I replaced all the ESC and motor connector with Castle Creation connectors and the problem is now gone. Quad fly's fine now.
Doug,
thanks for answer, I was just waiting for this one :)
So it is not only my impression that those ESC are not very suitable.
I just checked that again and holding the copter in hands I had several ESC reboots, simply by powering motors at full throttle. I had a lot of ESC reboots, but only on two of them. I tried moving cables to check for bad contacts, but reboots did not match with cables moved.
ESC reboots even without touching anything.
If an ESC reboots it seems more a power cable issue, rather than a motor connection.
Anyway I was wondering the same, putting four better ESC, but this will become expensive, so the concept of a cheap quadcopter is being erased.
Best regards,
Ric
Riccardo,
I'm using the stock ESC's and they work fine after replacing the connectors. If the ESC's are rebooting you most likely have a power supply problem. Maybe a bad solder connection on the power distribution board. I don't think you need to replace the ESC's. If the problem is on the power board and you replace the ESC''s you'll still have the same problem. Also make sure your battery connections are good to. Also, is the APM board rebooting to or just the ESC's? You may have a connection that is working fine when there is a low draw of current but when you advance the throttle which increases the current draw this causes the connection to open up and then the ESC's will reboot when the power comes back.
Doug,
could you please point me toward the connectors you are using ?
I have to unmount again all the electric part. I guess that having only one ESCs rebooting and two (three ?) glitching, it should be a connectors problem.
I checked for power consumption and get more than 50A at full throttle (average 45A. I got a peak at more than 80A, but this could be normal). So battery connection seems good. I never noticed an APM reboot.
Summarizing, motors glitches could be ESC motor connections issue; ESC reboot could be a power board ESC connection or a faulty / broken ESC.
Thanks for your inputs,
Ric
Ric,
I apologize I didn't remember this before. I also replaced the red Deans style connectors on the end of the ESC's and the ones being used on the power board. The felt like they were tight but the spring on the male side was not pushing the connectors together well enough to make a consistent connection. That would cause your ESC's to reboot. I went to the local hobby store and bought a full set of real Dean's connectors and replaced them all, I think this may be your problem. The connectors I used on the ESC to motor side were 3.5mm Castle Creations ones.
Doug,
this is very useful info indeed. Thank you. I will start changing all the Deans male connectors. I will report my results.
Best regards,
Ric
Ric,
I know it's more work, but I would and did change both the male and female Dean's connectors. With the nature of the way a Quad works the electrical connections must be perfect.
