Hey guys,
I need some help, I have had some issues where my quad has been repeatedly flipping over mid-flight. Once the quad is on the ground a very strange sound is emitted. I have checked my motors and ESC's and they are all perfect. I am thinking that it might be a glitch. I have a videobelow which continently catches it flipping. Luckily All I have broken so far is a few props and some nylon bolts.
Please help me!
***UPDATE***
Please look at my new discussion, the problem continues!!
Tags: crash, flip, flipping, over, random, unexpected, v2.4.1
Point taken, not really convinced though. I guess "peace of mind" could be a valid reason, but as I said I have never had problems with the connectors on the helis, so why should it be a problem on the quadcopter? OK, there are a factor of 4 more leads, so it is like flying 4 helis simultaneously and thus enhances the possibility of failure, that is true, but the current and vibration is probably higher on the helis. Anyway I really think that the emphasis on soldering the connectors that I witness in the forums seem to me to be blown out of proporsion. There are other factors involved here that are of far greater importance (IMHO). For instance I cannot understand that the current 2.4.1 release, which has a documented fatal error, is and has been for weeks the "recommended" release in the Mission Planner. Beats me. I have not flown since before christmas, because there has not been a release sufficiently safe to fly, in my opinion. Great hopes for the next 2.5 though :) After all the concept is awesome, and it will "soon" materialize I am sure of that, with so many great people working hard to improve the platform... I just hope that I very soon can take it out to do some real confident flying, and I dont think my worries will be the bullet connectors :)
I agree, I've had 1000's of flights with electric planes, heli's and now quads and I've never experienced a bullet connection failure. An EDF of mine at 1.3kW uses the same bullet connectors my quad uses and it's has no problems. I can understand that vibration can cause certain elements to fail or come loose, so I do check my bullet connectors occasionally on my quad but so far have not felt the need to solder them. Each to his own of course :)
Geir, fully with you on the fatal error in the release of 2.4.1, although admittedly it's only apparent on some platforms, Flown 4 x 11 minutes today with the upcoming 2.5 release from the git and it looks very good.
Permalink Reply by Craig Burden on March 17, 2012 at 10:01am I have just soldered all my connections and have reloaded v2.4.1 onto my APM, I have not had a chance to go buy some more prop's yet though so feedback on whether it was worth the effort is not yet available. I Am going to try buy some tomorrow, I will let you guys know what happens!
Permalink Reply by heikki.tukiainen on March 17, 2012 at 10:27am A random crasher gives an encouragment!
I had an issue with a flip --> a faulty motor -> changed it and worked fine.
Had a drift / lean issue (copter increasingly tilts to one direction and that needed to be compencated with right stick) --> increased P-terms in rate- roll, rate - pitch and rate- yaw & added padding to the board to remove vibrations
End result is a very steady quad. In low wind conditions it really with no hads. That was not possible with HK-board!
Thanks you all guys developing Arduboard! Thank you!
Permalink Reply by Todd Hill on March 17, 2012 at 10:59am Craig, have you considered your Lipo Batteries, and ESC. Is your ESC set to slow cut throttle when pack voltage decreases past a set amount. Check your pack voltage as well when it is fully charged. Do you know how to check the voltage for each cell?
I have wasted many hours in the past looking through logs, code, inspecting hardware instillation, only to discover It was a bad Lipo cell and ESC settings.
Check the nominal voltage of each cell charged and discharged.
Permalink Reply by Craig Burden on March 17, 2012 at 11:10am Todd, as I said previously I have tested all my ESC's and calibrated them with the TURNIGY programming card to the lowest cut off voltage with a soft cut off. I have check my battery before some flights with a battery voltage indicator. Also I fly with a battery monitor and therefore never come near the cut off voltage of my ESC's.
Thanks for the idea anyway.
Permalink Reply by Craig Burden on April 14, 2012 at 4:52am Guys please take a look at my new discussion, My problem is continuing!!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1289 members
182 members
24 members
681 members
248 members
Powered by
