All,
Which version of MAVLink does Arducopter v2.5.3 use? I want to used it with the latest version of QGroundControl, but the latest version of QGroundControl used MAVLink v1.0 and I can't seem to get QGroundControl to connect to my APM with the new v2.5.3 release. Can anyone advise as to which version of MAVLink Arducopter v2.5.3 uses and how to connect to it with QGroundControl?
Tags: 2.5.3, Arducopter 2.5.3, Arducopter v2.5.3, MAVLink, MAVLink v1.0, QGroundControl
ArduCopter 2.5.3/2.5.4 uses MAVLink 0.9. The next version of ArduCopter (2.6), which will be out in a couple weeks, uses MAVLink 1.0.
Permalink Reply by Donald R. Poole, Jr. on April 23, 2012 at 8:00am Thanks Chris for clearing this up for me!
Permalink Reply by Bart on April 23, 2012 at 6:17pm What are the plans with the mission planner? Will it support both, or switching entirely?
I will likely match the path taken with the mission planner with copter-gcs.
Thanks,
Bart.
the mission planner is mavlink 1.0 ready (compile time option), but will be a switch to 1.0 when needed. I dont support both because there are structs that have been modified between the 2, also the wp packet structure and a few other things has changed.
Permalink Reply by Joshua Lamorie on April 28, 2012 at 12:09pm I've been trying to build QGC with mavlink v0.9 on Linux (Fedora Core 16) and I have had nothing but problems. It seems that the v0.9 branches of QGC and Mavlink are not actually using the same versions of the header files.
Has anyone had success at building QGC from source for v0.9 for Linux (in the past month or two)?
Permalink Reply by lot on May 29, 2012 at 4:06pm Hi,
Anybody knows why QGroundControl says MAVLINK VERSION 3 if uses 1 ?
Like this image:
MAVLINK_VERSION 3
http://qgroundcontrol.org/_detail/users/serial-settings.png?id=user...
In my computer says version 2.
We are waiting for arducopter 2.6...
Thanks!
lot.
Permalink Reply by Donald R. Poole, Jr. on June 5, 2012 at 9:10am I'm not sure why that would be. You'll have to direct that question to one of the QGroundControl developers like James.
1288 members
57 members
680 members
87 members
Powered by
