Tags: apm, arducopter, calibration, doesn't, esc, lipo, plug, problem, start
Permalink Reply by Max Xam on July 4, 2011 at 9:50am Did have the same problem ones...reverse connection from the ESC connector to the APM.
Succes,
Max
Permalink Reply by Alexandre Loones on July 4, 2011 at 9:55am
Permalink Reply by Manel Garcia on July 4, 2011 at 10:45am Check your power distro and voltage out to APM/IMU, remember the red wire alwais is on center pin +
From top view connention is S + -
http://arducopter.googlecode.com/svn/images/PDistro_steps_REVC/6_to...
Manel
Permalink Reply by Alexandre Loones on July 4, 2011 at 10:51am i've just checked the 2 wires (red at centerpin and black on bottom) with my multimeter and he says : 5,0 V
My power distro is good because the 6 esc makes all bip when Mission Planner make the test just after the firmware upload.
But i've a 3S Lipo for my Hexa. is it enough ?
Permalink Reply by Alexandre Loones on July 4, 2011 at 1:01pm
Permalink Reply by Alexandre Loones on July 5, 2011 at 6:06am No solutions for me ?? no test to do ??
i've seen 2 solder holes near outputs with + and - .. does they power the APM ? Does 5V works into this ?
Help me please..
Permalink Reply by Alexandre Loones on July 6, 2011 at 9:32am
Permalink Reply by Manel Garcia on July 6, 2011 at 11:06pm Your wires likes right. Ardupilot damaged ??
I don´t know if have fuses.
Good Luck
Permalink Reply by Alexandre Loones on July 7, 2011 at 4:17am
Permalink Reply by Alexandre Loones on July 7, 2011 at 5:36am
Alexandre,
What are those ESCs? Do they have proper internal BEC?
Have your checked that ESC will output 5V from middle pin? You said that you measured 5v from bottom and middle pin on ESC connector but how about when connector is connected to APM R/C Connectors. Do other pins also see this +5v? You should see +5v between every middle and lower pins at APM 3 row pinheader.
Yes there are + and - holes on side of the PCB but you cannot put 5v to there, it should be higher like 7.2v.
3S is enough for hexa.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
720 members
1355 members
207 members
Powered by
