I have connected and uploaded the new code via mission planner. I have gone through the setup with the CLI and MP. When I slide the switch forward to the fly position and try to connect to the mission plannner it never connects even with gps lock? I've even tried to connect via Xbee's set at 56700, but nothing. All the lights are good "A" is solid green. I do NOT have it conneccted to the Rx or ESC does that matter? I'm trying to make sure everything is working first.
Tags: connecting, truoble
I Started a new post for my  Xbee connection problem
I'm getting the same issue. I had it working for a while and after a few reboots I can't get to the PIDs any more.
with or with out the xbee?  I can't get it to connect with the xbee. Connecting with the USB cable works great so far.
Just with USB. I had it working earlier today, no idea what changed.
To connect with Xbee over MAVLink add this to the APM_Config.h file:
#define GCS_PROTOCOL        GCS_PROTOCOL_MAVLINK
#define GCS_PORT                  3
#define SERIAL3_BAUD           57600  (or 115200 depending on your telemetry modems)
We'll add that to the default code today. Just an oversight in the version we released yesterday.
hello chris ,
i added this in the file but have a compile error
ArduCopterMega.cpp: In function 'void start_new_log(byte)':Log:263: error: 'get_log_boundaries' was not declared in this scope
I've added these lines, but I still can't get any of the mavlink stuff working in the mission planner over USB. The cli stuff works fine. Haven't tried with my xbees yet.
Right now, it's USB or Xbee, not both simutaneously. Default is USB. We'll support both simultaneously soon. Remember that they have different serial speeds (115k for USB, 57k for Xbee)
when u add those line witch i found out u only need these 2 lines
#define GCS_PORT                  3
Telemerty only works over XBEE when these lines are added.
USB will only talk in CLI mode
Oh sweet, the mavlink stuff works over xbees! Perfect! Thanks guys!
There seems to be a lot of dropped packets at 115200 baud, is this normal?
Same thing happened to me know with USB
I only use USB at this point. Everything was working fine. I updated to latest posted firmware, now I can only connect to mission planner in cli mode?
can't figure out what happened
Al
