Everything works fine until I get to the compass offsets. It displays scrolling data but everything is zero and never changes as I move the quad. I did run the CLI "a" command and made sure that the mag was activated.
Any Ideas what to check?
This Quad was flying fine with the RC_1 release, this happened when I upgraded to NG.I know that Rc_1 didn't use the compass.
Tags: Arducopter, ArducopterNG, Beta2, Compass, Offsets
Permalink Reply by DougB on December 18, 2010 at 11:51am I replaced the bad compass board with my second one and everything works now.
@Robert, You could have a bad board.
Doug
Permalink Reply by Robert Beatty on December 18, 2010 at 4:27pm Thanks for the info.
I have ordered a new one from DIY Drones' store with an explanation of the situation and a reference to this forum topic.
Permalink Reply by Michel Lubbers on December 19, 2010 at 2:39pm Hi Doug and Robert,
Make it three people.
Like you I get also only zeros with the CLI.
Tommorow I will take a closer look under a microscope.
Keep you posted.
Regard, Michel
Permalink Reply by DougB on December 19, 2010 at 4:55pm Michel,
I used my microscope today and there are 3 to 4 connections on the 8 pin chip closest to the connector side of the board that are clearly bad. You can see a break in the solder coming from the chip to the land. I'm going to have to send it back. :(
Permalink Reply by brakar on December 19, 2010 at 6:23pm I have not gotten around to test my mag.board yet, and doubt I ever will. Is de-soldering and re-soldering of tiny-tiny jumpers in the middle of that tiny board supposed to only require "basic" soldering skills?
Mags are all now shipped with the correct 5v default--no soldering needed. Is yours an older one? If so, send it to me and switch the solder jumper for you.
Permalink Reply by brakar on December 19, 2010 at 6:48pm Thanks, that would be great! I don't know how old the board is, I received it from the FahPah store about two weeks ago. (I will re-check the jumper with a magnifying-glass tomorrow).
address PM'd to you
Those are all new revisions just made about 1-2weeks ago so they should have 5v soldered as default.
Permalink Reply by Michel Lubbers on December 21, 2010 at 6:26am @ Doug & Robert,
All the soldering looks ok under the microscope.
There is a possibility that the i2c bus not functioning properly.
Is there anyway to test the i2c?
Regards, Michel
check if the pressure sensor works. It uses I2C as well
184 members
74 members
685 members
133 members
Powered by
