Hi -
I am not sure where to post this question so please let me know where I should post it if this is the wrong place.
I downloaded Arduino and ArduPlane.  I followed the instructions to set up Arduino.  I did the test build on the Examples->Basics->Blink and it builds correctly.  Then I tried to build ArduPlane and got the following error messages:
ArduPlane:239: error: new declaration 'uint8_t digitalRead(uint8_t)'
C:\Projects\arduino-1.0.4\hardware\arduino\cores\arduino/Arduino.h:100: error: ambiguates old declaration 'int digitalRead(uint8_t)'
ArduPlane:1288: error: expected constructor, destructor, or type conversion before 'int'
ArduPlane.pde: In function 'int SKETCH_MAIN(int, char* const*)':
ArduPlane:1288: error: 'OK' was not declared in this scope
compat.pde: In function 'uint8_t digitalRead(uint8_t)':
compat:33: error: new declaration 'uint8_t digitalRead(uint8_t)'
The following are my notes:
Line 239 is actually a comment line in ArduPlane:
// a pin for reading the receiver RSSI voltage. The scaling by 0.25
Line 100 in Arduino.h is:
int digitalRead(uint8_t);
Line 1288 in ArduPlane is:
AP_HAL_MAIN();
What do I need to do to fix these errors and get a build to work with Arduino and ArduPlane?
What is the preferred environment for doing development on ArduPlane?
-- OS?
-- IDE?
I looked at CodeBase - it looked pretty good but, I am not sure how to get everything set up properly to do builds of ArduPlane and ArduCopter.
Any help on these things would be greatly appreciated.  I am looking forward to doing ArduPlane development.
Sid
Oh - I should mention that I am running on a Windows 7 PC.
Sid
No worries I moved it to the Autopilot/software section as that is where the code heads tend to congregate.
